Mirror modifier bug - Bisect mode results in “automerge” even if it shouldn’t. Most likely due to units setup put to cm. #85051
5 Participants
Reference: blender/blender#85051
Operating system: Windows 10
Graphics card: GeForce GTX 970
Broken: All Blender versions including the latest 2.91
Worked: Never
Hello guys,
The mirror modifier doesn't do it's job properly when having "bisect" enabled. There is a hidden threshold to which it will snap vertices to the mirror line.
I ruled out all possible things, the mirror pivot is perfectly zeroed out and there is no merge enabled and also no auto merge. Stan from Blenderartists pointed out that switching to meters and scaling the object up 100 times “solves” the problem, so it's most likely a bug related to having switched the units to cm.
It's also not specific to the latest Blender version, it does the same error in older versions. I attached the scene so you can take a look at it. bug.blend
Load up the scene and simply put it to "bisect" and you will see how it merges the verts when it shouldn't.
Added subscriber: @ChamferZone
#86289 was marked as duplicate of this issue
Mirror modifier bug - Bisect mode results in “automerge” even if it shouldn’t. Most likely do to units setup put to cm.to Mirror modifier bug - Bisect mode results in “automerge” even if it shouldn’t. Most likely due to units setup put to cm.Added subscriber: @filedescriptor
I can confirm this issue on master and 2.92 beta.
Added subscriber: @Stan_Pancakes
Added subscriber: @WCN
The bisect threshold is currently hardcoded to 0.001f. My "fix" just makes this threshold smaller, but a better solution would be to expose this threshold similar to the merging threshold.
Is exposing another threshold setting really a better solution? It'd promote a worse UX, IMHO. It'd probably be better if both bisect and merge used the same threshold, or (preferably) if bisect didn't even touch verts that aren't on the bisect plane at all (i.e. only merged any stray dupes that happen to be connected to the generated edge).
This issue was referenced by
00ec99050e
