- rB3191b76eb53 GPencil: Noise Modifier - Move noise seed value ou...f randomize subpanel (Cody Winchester)
- rB33a558bf215 Geometry Nodes: support accessing UV layers with attribute system (Jacques Lucke)
- rB5a1cef2e763 UI: move 'Trace Image to Grease Pencil' to 'Convert' sub-menu (William Reynish)
- rB6704372f047 GPencil: Allow small resolution for Fill tool (Antonio Vazquez)
- rB685419d6beb UI: Object 'Make Links' sub-menu overhaul (William Reynish)
- rB7a4bdc3a4fe Gpencil Noise - Add noise offset parameter (Cody Winchester)
- rBcfd54ad7d78 GPencil: New option to Duplicate Layers with Empty Keyframes (Antonio Vazquez)
- rBda2955fdf66 UI: improve categorization in Grease Pencil Layers sub-panels (William Reynish)
- rBded9484925e UI: Viewport Navigate Gizmo Refactor (Harley Acheson)
- rBe02d84eb3be GPencil: Add new parameteres to transform layers (Antonio Vazquez)
- rBe747c07156c GPencil: New option to trace current frame (Antonio Vazquez)
- rBe7c36ce43cf GPencil: Disable Multiframe edition when play animation (Antonio Vazquez)
- rBeb45e7be47f UI: particle tool properties layout tweaks (Campbell Barton)
- rBf17b26bbed3 Tracking: Implement tracks average operator (Sergey Sharybin)
- rBe02d84eb3bea GPencil: Add new parameteres to transform layers (Antonio Vazquez)
- rB425e706921a8 Geometry Nodes: new Attribute Sample Texture node (Jacques Lucke)
- rB8b777ee6d69d Geometry Nodes - Object Info: option to apply obj transform to the geometry (Dalai Felinto)
- rB0af512abdf0 Sky Texture: change Nishita Altitude to use unit system (Marco)
- rB1352d81b174 GPencil: Fill tool refactor and Multiframe in Draw mode (Antonio Vazquez)
- rB1c4b0c47dd4 Geometry Nodes: Support all operations in the 'Attribute Math' node (Hans Goudey)
- rB1f5647c07d1 UI: FModifier layout updates, drag and drop (Hans Goudey)
- rB4d39a0f8eb1 Geometry Nodes: Add Attribute Proximity Node (Victor-Louis De Gusseme)
- rB4f8bc3e35ca GPencil: Move Autofit parameter from topbar to advanced panel (Antonio Vazquez)
- rB53bf04f2844 Geometry Nodes: Expose material index attribute (Hans Goudey)
- rB66151b5de3f Subsurf: Expose all UV interpolation options (Sergey Sharybin)
- rB6bba8305898 GPencil: Interpolate Tools refactor (Antonio Vazquez)
- rB7d874b03433 Image: Flip image operator (Pablo Dobarro)
- rB8f707a72e81 UI: Multi-input node socket spacing and interaction (Fabian Schempp)
- rB9a9e19fdcc4 Geometry Nodes: Use multi-input socket in join geometry node (Fabian Schempp)
- rBa2ba37e5b63 Geometry Nodes: Add Combine and Separate XYZ nodes for attributes (Wannes Malfait)
- rBc5514d3a2a0 Geometry Nodes: Multi-Input Sockets (Fabian Schempp)
- rBd4fd06d6ce8 Geometry Nodes: Add operation setting to attribute randomize node (Hans Goudey)
- rBee1c674775f UI: Use property split in geometry node properties (Hans Goudey)
- rBf2bf5acd582 Keymap: use Shift-Tab to cycle backwards over edit-buttons (Campbell Barton)
Related Objects
Related Objects
- Mentioned Here
- rB66151b5de3ff: Subsurf: Expose all UV interpolation options
rB1c4b0c47dd47: Geometry Nodes: Support all operations in the "Attribute Math" node
rB0af512abdf05: Sky Texture: change Nishita Altitude to use unit system
rBc5514d3a2a03: Geometry Nodes: Multi-Input Sockets
rBf2bf5acd5824: Keymap: use Shift-Tab to cycle backwards over edit-buttons
rB4d39a0f8eb11: Geometry Nodes: Add Attribute Proximity Node
rB7d874b03433d: Image: Flip image operator
rB1352d81b1747: GPencil: Fill tool refactor and Multiframe in Draw mode
rBa2ba37e5b631: Geometry Nodes: Add Combine and Separate XYZ nodes for attributes
rB9a9e19fdcc48: Geometry Nodes: Use multi-input socket in join geometry node
rB8f707a72e818: UI: Multi-input node socket spacing and interaction
rB4f8bc3e35ca2: GPencil: Move Autofit parameter from topbar to advanced panel
rBd4fd06d6ce89: Geometry Nodes: Add operation setting to attribute randomize node
rB53bf04f2844b: Geometry Nodes: Expose material index attribute
rB1f5647c07d15: UI: FModifier layout updates, drag and drop
rB6bba83058986: GPencil: Interpolate Tools refactor
rBee1c674775fd: UI: Use property split in geometry node properties
rB8b777ee6d69d: Geometry Nodes - Object Info: option to apply obj transform to the geometry
rBbcdba7c34da0: UI: Deselect other objects when dragging into 3D View
rB908b383b7d21: UV: tweak face select behavior
rB425e706921a8: Geometry Nodes: new Attribute Sample Texture node
rBb4b02eb4ff77: UI: Transform Arrow Cursor Refactor
rBdb15df0baaad: Asset Browser: Support dragging image assets into node editors
rBb449da3a7d48: Asset Browser: Support dragging mask assets into compositors
rBc8d6e2dfa0e0: UI: Avoid showing drop hint on drag & drop if dropping won't succeed
rB2fec46c3e614: Asset Browser: Support dragging in object-data assets (meshes, curves, etc.)
rBcf6d17a6aa42: UI: Gizmo Tooltip Positioning
rBd1c6704413b5: UV: tweak island select behavior
rBd6bbcc4f666b: VSE: Inherit blend mode with single input effects
rB5f55022276a8: UI: tweak object context menu labels
rB5f2c5e5bb8c1: UI: object context menu tweaks for consistency
rB21b9231d7f5a: Transform: geodesic distances for proportional edit connected mode
rBcdfa3feb9111: Add Object Tool: support incremental snapping
rBfef7b792e763: Add Object Tool: make UI more compact
rBecffd231a008: Add Object Tool: add initial "Fixed Aspect" option
rBf7829961c64f: Add Object Tool: include shortcuts in the tool-tip
rB5f9358a373cb: Add Object Tool: split aspect & origin options for base/height
rB06da6e2eaf76: Add Object Tool: scale the cursor plane based on the depth
rB2ee2f87f29bb: Add Object Tool: move extra settings popover last
rBe7c36ce43cf6: GPencil: Disable Multiframe edition when play animation
rB3191b76eb534: GPencil: Noise Modifier - Move noise seed value outside of randomize subpanel
rB6704372f047c: GPencil: Allow small resolution for Fill tool
rB33a558bf2157: Geometry Nodes: support accessing UV layers with attribute system
rB7a4bdc3a4feb: Gpencil Noise - Add noise offset parameter
rBa51584dc70ac: Geometry Nodes: transfer corner and point attributes in Point Distribute node
rBe02d84eb3bea: GPencil: Add new parameteres to transform layers
rBf5ec29023dca: GPencil: Fix initial value for fill factor after last changes
rBf17b26bbed3d: Tracking: Implement tracks average operator
rB685419d6bebf: UI: Object "Make Links" sub-menu overhaul
rBeb45e7be47f7: UI: particle tool properties layout tweaks
rBcfd54ad7d78e: GPencil: New option to Duplicate Layers with Empty Keyframes
rBded9484925ed: UI: Viewport Navigate Gizmo Refactor
rBe747c07156cc: GPencil: New option to trace current frame
rB5a1cef2e763f: UI: move 'Trace Image to Grease Pencil' to 'Convert' sub-menu
rBda2955fdf66d: UI: improve categorization in Grease Pencil Layers sub-panels
