Cycles GPU render crashes in 2.92, 2.93 on Ubuntu with rx580 #85099
5 Participants
Reference: blender/blender#85099
Operating system: Ubuntu 20.04.1 LTS and popOS 20.10
Graphics card: Radeon RX 580
Broken: 2.93.0 Alpha, branch: master, commit date: 2021-01-27 04:28, hash:
fc669a4c3e
2.92.0 Beta
Worked: 2.83.1, 2.90.1, 2.91.2
Blender crashes in 2.92 and 2.93 when loading render kernels in cycles GPU render.
Tried both download from blender.org and build from master. Older versions works fine.
system-info.txt
blender.crash.txt
blender_debug_output.txt
Added subscriber: @Svend
Added subscriber: @mano-wii
I don't know if it can help, but I see in the logs some messages of
"not found in cache"
and"not found on disk"
so...Try to delete the cache files in
/home/svend/.cache/
in order to recreate them.Changed status from 'Needs Triage' to: 'Needs User Info'
Did deleting the cache files make any difference?
Thanks for the suggestion!! I was wondering where the render kernels where saved and completely missed the cycles folder next to the blender folder.
No unfortunately not. Deleting the kernels; 2.92, 2.93 still crashes. 2.83 and 2.90 fine. 2.91 works but writes “Split kernel error: failed to load kernel_lamp_emmission” in the view port while building the kernel and you have to “reload” it by clicking another view and then back to render view. After this it works fine.
I thought maybe the load kernel_lamp_emmission might also be the problem in 2.92-3 because it was in the debug_output file ??!?
Tried everything I could think if incl removing/installing the AMD OpenCL driver from both version 20.10 and 20.40. Did also delete everything in cache as sugested, not just kernels .
Can anyone confirm that they can make the cycles GPU render kernels in ubuntu with a rx580 (or similar amd card) in either 2.92 or 2.93? If so I’ll try a fresh system install.
Thanks for the help and have a nice weekend when you get to it :)
This
is a known issue that appeared in recent AMD drivers for this GPU.The strange thing is that this problem has only been seen on windows.
See #84461 (Cycles: Split kernel error with OpenCL)
So I'm not sure if it's a duplicate.
The machine is actually a MacPro so I guess we have a full circle ;)
(and yes I am booting directly in to ubuntu/pop, not a virtual machine or whatever.)
Not sure either. One difference to #84461 is that even though I get the same error it actually works in 2.91 in my case. It was rendering happy as Larry for 5-6 hours the other day. Do you know what exactly the kernel_lamp_emmission does? Maybe my renders didn’t actually need it. I’ll be happy to run a test render if it can help.
Added subscriber: @JanneM
Tried a completely fresh Pop OS 20.10 install and OpenCL from 20.40. Same result :(
2.83.12 works
2.91.2 Split kernel error: failed to load kernel_lamp_emmission, but appears to work fine when kernels are loaded again.
2.92.0 Crash
Maybe #84579 is the same problem??
Added subscriber: @iandol
Added subscriber: @WojciechZakroczymski
Added subscriber: @thomas-29
Workaround for cycles kernel build crash on RX5x0 on Linux
Huge thank you to @thomas-29 for sharing this in #86610 !!!
After looking around I did the same just in a different place. Looks like it was introduced in Cycles: Enable NanoVDB usage by default,
bd6bfba64d
By reverting this I can now render with my RX580 again
bd6bfba64d
by changing line 206 to off in CMakeLists.txtThe first time blender builds the kernels it gives an error (failed to load kernel_path_init) - Assume it’s the same problem as in 2.91.x described above - Try again and it now works :)
To test I rendered bmw27, Classrom. No problems.
Downside; no rendering of volume objects on GPU. Did not test this but, Thomas mentioned it.
Whats the best way to friendly poke the cycles team? Maybe knowing that NanoVDB seems to be the cause there is a simple fix for the AMD cards?
Hopefully this would also fix;
#86610
#85698
#84579
#86182
#86248 (Radeon Pro WX5100)
#85099
Update: As I was writing this, it looks like thomas-29 #86610 just found a solution so it also works with volumes :) Thanks !
Thanks, did a fresh build and
91c44fe885
seems to have removed the crash :) Do I change the status or is that done by an admin?The split kernel error is still there!
First time Blender is compiling render kernels I get the following error:
When I try again it's much faster compiling and all now works fine.
I don't think it has anything to do with subsurface scatter. The error has been there since 2.91 and other versions failed to load other kernel_whatever. Did a few render tests with subsurface scatter, all fine as far as I can tell.
Is this a known bug? or should i make a separate bug report for it?
Thanks for the info.
The split kernel appears to be a different problem and is probably related to #84461 (Cycles: Split kernel error with OpenCL).
So I will close this report.
