Selected tool isn't highlighted blue while mouse is over it, if selected via shortcut
Broken: 2.8 to 2.92
If selected via shortcut, the selected tool isn't highlighted blue while mouse is over it.
Alternatively if you hover the mouse over the selected tool and press another tool shortcut, both tools will be highlighted blue (as selected) until moving the mouse away.
Open default startup.
Click to select the Transform tool.
Hovering with the mouse over "Select Box" tool, press W (Select Box shortcut).
No tool will be highlighted as selected until you move the mouse away.
Alternatively
Select the Transform tool.
Hovering with the mouse over the Transform tool, press W (Select Box shortcut).
Both tools will be highlighted as selected until you move the mouse away.
Robert Guetzkow (rjg) changed the task status from Needs Triage to Confirmed.EditedJan 27 2021, 1:21 PM
Robert Guetzkow (rjg) triaged this task as Low priority.
Seems like the toolbar's active tool drawing isn't refreshed properly. I'm marking this as low priority as this disappears as soon as the mouse is moved and the actual functionality works as intended. The issue is purely in the visual display.
I agree that this is low priority
