Blender crashes
Operating system: Windows 10
Graphics card: RTX 2080S super
Blender Version 2.91
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
Worked: (the newest version of Blender that worked as expected)
When I try to render with Cycles, Blender crashes at the beginning showed some CUDA error and did not want to render. Now Even even when I try to switch to Cycles render crashes the Blender and stopped working. please help I cannot work like that.
Robert Guetzkow (rjg) changed the task status from Needs Triage to Needs Information from User.Jan 28 2021, 9:36 PM
Please open Blender's installation directory and double click on the blender_debug_gpu.cmd. This will start Blender in debug mode and create log files. Try to make Blender crash again. Once it crashes the Windows Explorer should open and show you up to two files, a debug log and the system information. Add them to your bug report by clicking on the upload button as shown in the screenshot below or via drag and drop. Please also upload the crash log located in C:\Users\[your username]\AppData\Local\Temp\[project name].crash.txt (or simply type %TEMP% into the path bar of the Windows Explorer).
Robert Guetzkow (rjg) closed this task as Archived.Feb 11 2021, 9:16 PM
