Use Blender 2.90.1 in blender-benchmark. #85187
Priority::High
Priority::Low
Priority::Normal
Status::Archived
Status::Confirmed
Status::Duplicate
Status::Needs Information from Developers
Status::Needs Triage
Status::Resolved
Type::Bug
Type::Design
Type::Report
Type::To Do
2 Participants
Reference: infrastructure/blender-open-data#85187
Blender Open Data currently uses Blender 2.90.0 as its latest version. We haven't updated to 2.91 as a new version of the
benchmark_script
is needed (See #83002 (Add support for Blender 2.91)).Nevertheless AMD and AWS requested to use the latest Blender 2.90.1 as an important issue has been solved that will allow successful rendering of big scenes using AMD GPUs (See blender/blender@0f72e7c3eb) This is needed for their Q&A process.
I would propose to run the following script on the opendata postgres database. The script will replace the table entries of 2.90 to use 2.90.1.
I haven't been able to test this so I want to go over the process in constructing this script.
Before executing I recommend to run the following SQL statement so we could rollback when there is an issue with the statements above.
In order to test if the change is correct we should look at the result of https://opendata.blender.org/benchmarks/metadata/, start blender-benchmark that should download Blender 2.90.1 and start the blender version that is downloaded to verify that the correct version is used.
Added subscriber: @Jeroen-Bakker
Added subscribers: @fsiddi, @railla
I added the 2.90.1 build and tested on macOS. If you could confirm that it works on Linux and Windows then this issue can be closed.
Confirmed that they work!
