Grease pencil strokes are incorrectly blended with geometry in draw mode (depending on 'Fade Inactive Geometry' setting) #85207
Open
opened 2021-01-29 17:58:02 +01:00 by Thomas Mann · 11 comments
Operating system: Win 10
Graphics card: ATI Radeon 5700
Broken: (example: 2.92b, 213f8*, master, 2021-01-28, as found on the splash screen)
note: this is due to Fade Inactive Geometry being ON
When drawing grease pencil strokes with a black material the rendering style changes when...
  • ...switching between draw-mode and edit mode, or
  • ... toggling the overlay button in draw mode (even will all overlay options disabled).
This leads to noticeable rendering artifacts while drawing. Please consider the following screenshots:
overlays on:
overlay off:
Some assumptions:
  • I assume that the blend modes are not correctly set and thus interfere with the MSAA.
  • The white artifacts are especially pronounced for thin strokes of all opacities. Increasing the thickness factor slightly decreases the problem.
Load the following blender file
stroke-test.blend
Step by step:
  1. Start blender
  2. Create Cube
  3. Create Grease Pencil
  4. Add new material for grease pencil and change to black
  5. Draw strokes (with different opacities)
  6. Switch between Draw and Object mode or toggle Overlay-Toggle
**System Information** Operating system: Win 10 Graphics card: ATI Radeon 5700 **Blender Version** Broken: (example: 2.92b, 213f8*, master, 2021-01-28, as found on the splash screen) **Short description of error** note: this is due to `Fade Inactive Geometry` being ON When drawing grease pencil strokes with a black material the rendering style changes when... - ...switching between draw-mode and edit mode, or - ... toggling the overlay button in draw mode (even will all overlay options disabled). This leads to noticeable rendering artifacts while drawing. Please consider the following screenshots: overlays on: ![image.png](https://archive.blender.org/developer/F9604146/image.png) overlay off: ![image.png](https://archive.blender.org/developer/F9604149/image.png) Some assumptions: - I assume that the blend modes are not correctly set and thus interfere with the MSAA. - The white artifacts are especially pronounced for thin strokes of all opacities. Increasing the thickness factor slightly decreases the problem. **Exact steps for others to reproduce the error** Load the following blender file [stroke-test.blend](https://archive.blender.org/developer/F9604151/stroke-test.blend) Step by step: 1. Start blender 2. Create Cube 3. Create Grease Pencil 4. Add new material for grease pencil and change to black 5. Draw strokes (with different opacities) 6. Switch between Draw and Object mode or toggle Overlay-Toggle
Author
Added subscriber: @pixtur
#89974 was marked as duplicate of this issue
#85600 was marked as duplicate of this issue
#84058 was marked as duplicate of this issue
Member
Added subscriber: @lichtwerk
Member
Member
Can confirm, this is due to Fade Inactive Geometry being ON.
This setting is not available in GPencil modes [maybe it should though, see {D10215}], to turn it OFF you can e.g. go to mesh editmode.
This should not affect Greasepencil drawing though.
Can confirm, this is due to `Fade Inactive Geometry` being ON. This setting is not available in GPencil modes [maybe it should though, see {[D10215](https://archive.blender.org/developer/D10215)}], to turn it OFF you can e.g. go to mesh editmode. This should not affect Greasepencil drawing though. ![#85207.png](https://archive.blender.org/developer/F9607835/T85207.png)
Philipp Oeser changed title from Grease pencil strokes are incorrectly blended with geometry in draw mode (with show Overlays active) to Grease pencil strokes are incorrectly blended with geometry in draw mode (depending on 'Fade Inactive Geometry' setting) 2021-02-01 16:25:22 +01:00
Author
That would be great. An ideal solution should allow users to overlay certain elements (e.g. the Stroke Canvas) without altering the rendering of the strokes.
Member
Added subscribers: @ArnoldLynx, @filedescriptor, @fclem
Member
Added subscribers: @nestorantonio, @AnityEx, @dupoxy
Added subscribers: @Vyach, @iss, @PratikPB2123
Philipp Oeser removed the
label 2023-02-10 09:12:02 +01:00
Reference: blender/blender#85207
