new boolean difference meshing issue with surfaces #85217
Reference: blender/blender#85217
Operating system: Darwin-19.6.0-x86_64-i386-64bit 64 Bits
Graphics card: NVIDIA GeForce GTX 775M OpenGL Engine NVIDIA Corporation 4.1 NVIDIA-14.0.32 355.11.11.10.10.143
Broken: New Boolean code - version: 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash:
0f45cab862
Worked: Old Boolean code works
new boolean code does seem to have mesh intersection issues
when dealing with a solid it works better
intersect to surfaces
add a boolean difference modifier
to make it work add a solidify modifier before the boolean modifier
Boolean Issue.blend.zip
Added subscriber: @ClaasKuhnen
Added subscribers: @howardt, @rjg
Without solidify the geometry is non-manifold so this might be a case similar to #84493 @howardt?
This is indeed the same general issue: Boolean is not guaranteed to work when both operands are not volume enclosing. The old boolean will have issues too in certain orientations of the mesh. The code I have been playing around with seems to do better in this case. I just need to test it more before committing.
@howardt I see ok so this is just a limit - period.
Maybe surfaces work maybe not
In general simply only use volumes ?
Too bad - solid modeling is great but only can get you sofar.
Sometimes you need surface trimming too.
If both operands are not volumes, trimming can be kind of ambiguous. You could say a difference A - B, where A, and B are both non-closed surfaces means: discard everything on the positive normal side of B from A, but I could draw lots of pictures where it is not clear what is on "the positive normal side of B", if B doesn't extend to effectively infinity. I'm sure you can image this.
If B is a closed volume, the ambiguity goes away, and I am comfortable saying that Boolean will do the expected "discard everything from A that is not inside B", which can do the trimming you desire. Other cases may work, or maybe not, no real way to guarantee.
I am about to submit code that should work a little better than the current code in situations where both are not volumes. As I said above, it makes the example in this bug work.
Added subscriber: @howard
@howard
Oh yes I can very understand. Looking forward to the changes.
Added subscriber: @filedescriptor
Will mark this as a known issue.
