Particle color from instancer not right in render when "Use Modifier Stack" box is checked (Cycles) #85218
2 Participants
Reference: blender/blender#85218
Graphics card: GeForce GT 710/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 445.75
Broken: version: 2.91.2, branch: master, commit date: 2021-01-19 16:15, hash:
5be9ef4177
Particle color inherited from instancer is disabled if there is a subdivision surface modifier above the particle modifier, and the "Use Modifier Stack" box is checked in the particle settings under the Source drop down.
Unchecking the box, or moving the particle modifier to the top fixes the problem.
#85218.blend
Original instructions
Make plane, assign plane an image texture material, add subdivision surface modifier, add particle system, add a cube, assign cube to be the particles, give cube the same image in it's own material using the UV map from instancer. Particle cubes should now be the color from the spawning point of the instancer.
In the particle settings under Source check the "Use Modifier Stack" box. Put the subdivision surface modifier at the top of the stack. Particles will now turn gray in the render. In the Blend file I was working on, they showed the correct color, but the render color was gray. When I uncheck the "Use Modifier Stack" box, it renders correctly. In my test file, the render preview also shows gray particles. I'm not sure what the difference is. I'm including both Blend files.
Particle test.blend
Bauble Test.blend
Render preview window
Actual render
Thanks! this took awhile to figure out. I think this is an actual bug, because I can see no reason this should cause this error.
Added subscriber: @Spaceboy64
Added subscriber: @rjg
This does seem to be incorrect. I will try to simplify the example to see where at what part this is going wrong, but this might be an issue in the particle system code that is considered to be at its end of life and planned to be replaced.
It seems that Use Modifier Stack results in the correct placement of the particles but the UV Map is wrong when From Instancer is enabled.
In the project below the texture
emit-control
is used in the hair particle system to control the density (see Texture Influence ). The cube is used as render object for the particle system. It has a material which uses the UV map of the instancer and uses this to sample the color from the texturecolor
.#85218.blend
This may be the same issues as reported in #57922.
Closed as duplicate of #57922
