Align to Transform Orientation Not Working
Closed, ResolvedPublicBUG
Operating system: Darwin-17.7.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon HD 6770M OpenGL Engine ATI Technologies Inc. 4.1 ATI-1.68.25
Broken: version: 2.91.2, branch: master, commit date: 2021-01-19 16:15, hash: rB5be9ef417703
Worked: 2.91.0 Stable
Align to Transform Orientation Not working correctly
Select plane, F3 Align to transform orientation > Select 'View' from 'orientation' box.
Not aligned to view.
Mentioned in 20f8130d6f90 https://developer.blender.org/rB20f8130d6f905321059200756d18e9fffab60b7f
@Germano Cavalcante (mano-wii)
Also not working in latest nightly build:
version: 2.92.0 Beta, branch: master, commit date: 2021-01-29 16:08, hash: 5d215d522541, type: Release
build date: 2021-01-30, 00:15:11
Robert Guetzkow (rjg) changed the task status from Needs Triage to Needs Information from User.Jan 30 2021, 2:10 PM
It does change the orientation for me in the same way in both 2.91.0 and 2.91.2. The object's Z-axis is aligned with the viewing direction.
  1. Add > Mesh > Monkey and keep Align set to Global
  2. Use Object > Transform > Align to Transform Orientation and set Orientation to View
What result are you seeing in Blender 2.91.2?
I also can't reproduce the issue in rB5d215d522541, same behavior as before. Did you mean that it doesn't produce the same result as the Align option when creating the object?
I can reproduce it for blender version : 2.92.0 alpha .
Germano Cavalcante (mano-wii) changed the task status from Needs Information from User to Confirmed.Jan 30 2021, 5:00 PM
I can confirm that Align to Transform Orientation does not behave as before with the View orientation.
Regression introduced in rBf9e994d0f463: Fix T83092: Direction of rotation with View orientation changed in 2.91.
