Copy Rotation World Space to World Space flips when applying Mix Before, After or Legacy #85350
Closed
opened 2021-02-04 00:02:40 +01:00 by Colin Knueppel · 10 comments
Operating system: Windows 10
Graphics card: Radeon RX Vega
Broken: (example: 2.91, edbf15d3c0, master, 2018-11-28, as found on the splash screen)
Worked: not since implementation in f4056e9ec3
  1. Create a single bone armature.
  2. Shift + D duplicate bone and offset location for clarity.
  3. Ctrl + Tab into Pose mode.
  4. Select original bone and shift select the second bone.
  5. Ctrl + Shift + C to Copy Rotation constraint the duplicate to the original.
  6. Select the constrained bone and change Mix setting to before original and observe the immediate flip.
    The flip is the bug.
#85349.blend
Expected behavior is to have the bone orientation match the world orientation of the the target and animate as though the world space of the target is its base pose. World Space to World Space should align absolutely, and if the purpose of some of these mixes is to allow the users to animate over a constraint, the base behavior should still work as expected.
Without this working as expected, people need to devise work arounds using more bones and constraints, which could be time consumptively non-obvious, clutter the rig with added bones/constraints, and convolute what could otherwise be an intuitive and concise solution.
Thanks for your time and consideration.
Sincerely,
Colin
**System Information** Operating system: Windows 10 Graphics card: Radeon RX Vega **Blender Version** Broken: (example: 2.91, edbf15d3c044, master, 2018-11-28, as found on the splash screen) Worked: not since implementation in f4056e9ec3 **Short description of error** **Exact steps for others to reproduce the error** 1. Create a single bone armature. 2. Shift + D duplicate bone and offset location for clarity. 3. Ctrl + Tab into Pose mode. 4. Select original bone and shift select the second bone. 5. Ctrl + Shift + C to Copy Rotation constraint the duplicate to the original. 6. Select the constrained bone and change Mix setting to before original and observe the immediate flip. The flip is the bug. [#85349.blend](https://archive.blender.org/developer/F9632506/T85349.blend) Expected behavior is to have the bone orientation match the world orientation of the the target and animate as though the world space of the target is its base pose. World Space to World Space should align absolutely, and if the purpose of some of these mixes is to allow the users to animate over a constraint, the base behavior should still work as expected. Without this working as expected, people need to devise work arounds using more bones and constraints, which could be time consumptively non-obvious, clutter the rig with added bones/constraints, and convolute what could otherwise be an intuitive and concise solution. Thanks for your time and consideration. Sincerely, Colin
Author
Added subscriber: @colleyd
Member
Added subscriber: @lichtwerk
Member
Member
Might be me, but I also cannot make sense of it "not working" in anything but local space.
Implemented in f4056e9ec3
Might be me, but I also cannot make sense of it "not working" in anything but local space. Implemented in f4056e9ec3
Member
Added subscriber: @angavrilov
Member
@angavrilov: are we doing something wrong?
First, as soon as this is arguing how things 'should' work, this is definitely a feature request and not a bug. Second, space and mix mode are completely unrelated and in a node system would be separate nodes. You effectively are arguing that different settings of a coordinate space conversion node 'should' affect what a matrix math node does.
Member
Added subscriber: @wbmoss_dev
Member
A solution may be to separate Owner space into Read and Write spaces. For this case, Owner Read=Local and Owner Write=World. This leads to
Owner World = Target World @ Owner Local
as desired.
A solution may be to separate Owner space into Read and Write spaces. For this case, Owner Read=Local and Owner Write=World. This leads to Owner World = Target World @ Owner Local as desired.
Philipp Oeser removed the
label 2023-02-09 14:35:54 +01:00
Member
This isn't a bug, but rather an easy point of confusion. Basically, the situation is the following:
  • Perhaps weirdly, Blender doesn't create new bones in an "untransformed" position. Any bone that is pointing up is actually (in terms of world space) rotated 90 degrees to do so. And that is the default position of new bones (including the default bone in a new armature). An untransformed bone (in terms of world space) would actually be pointing back, down the positive Y axis.
  • Due to this, the world-space rotation of the default (pointing up) bone is actually 90 degrees.
  • Therefore, with two pointing-up bones and a constraint operating in world space, if you set the mix mode to anything other than Replace (all of which try to combine the rotations of the two bones), the transform system correctly-but-confusingly sees two 90-degree world-space rotations.
  • Therefore, when those two rotations are combined, you get a 180-degree rotation, which puts the bone pointing away from the positive Y axis.
Since this isn't a bug, I'm closing the issue. However, I do think this indicates we might want to re-think what the default position of new bones is, so that simple tests like this reveal what's going on in a more straightforward way to users.
We could also try to figure out a way to make it more obvious/clear how spaces and mix modes interact. But I think there are some fundamentally tricky-to-wrap-your-head-around things about it, so I doubt something as simple as e.g. label changes or better tool tips would make a meaningful difference here (although improvements there are always welcome). I suspect it would need to be something like adding visualizations in the 3d viewport of what's going on, which would be a significant feature to design and implement.
This isn't a bug, but rather an easy point of confusion. Basically, the situation is the following: - Perhaps weirdly, Blender doesn't create new bones in an "untransformed" position. Any bone that is pointing up is actually (in terms of world space) rotated 90 degrees to do so. And that is the default position of new bones (including the default bone in a new armature). An untransformed bone (in terms of world space) would actually be pointing **back**, down the positive Y axis. - Due to this, the world-space rotation of the default (pointing up) bone is actually 90 degrees. - Therefore, with two pointing-up bones and a constraint operating in world space, if you set the mix mode to anything other than `Replace` (all of which try to *combine* the rotations of the two bones), the transform system correctly-but-confusingly sees two 90-degree world-space rotations. - Therefore, when those two rotations are combined, you get a 180-degree rotation, which puts the bone pointing *away* from the positive Y axis. Since this isn't a bug, I'm closing the issue. However, I do think this indicates we might want to re-think what the default position of new bones is, so that simple tests like this reveal what's going on in a more straightforward way to users. We could also try to figure out a way to make it more obvious/clear how spaces and mix modes interact. But I think there are some fundamentally tricky-to-wrap-your-head-around things about it, so I doubt something as simple as e.g. label changes or better tool tips would make a meaningful difference here (although improvements there are always welcome). I suspect it would need to be something like adding visualizations in the 3d viewport of what's going on, which would be a significant feature to design and implement.
Blender Bot added
and removed
labels 2023-05-08 12:26:02 +02:00
5 Participants
Reference: blender/blender#85350
