Cube projection size parameter is wrong #85379
Reference: blender/blender#85379
Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.09
Broken: version:
b50598bc78
Worked: Never
When using Cube projection UV mapping operator, the resulting cubic projection size is actually double of the size displayed in the user interface. So when you perform a cube projection with the size 1.0, which would imply a cube of a size of 1 blender unit, which should be 1 meter, but size of the cubic projection actually ends up 2 meters wide. This is probably remnant of the old weird times when cube primitive in Blender was specified using a radius value instead of size value.
Result: In the UV editor, the cube UV faces do not match the edges of UV space perfectly despite the size of the 3D cube in the viewport matching the Cube Size value set in Cube Projection operator.
Expected. The UV faces in the editor match the edges of the UV space perfectly, since a Cube Projection with a size of 1.0 was applied on a Cube mesh with a size of 1.0 and 1.0 scale transform.
Added subscriber: @Rawalanche
Added subscriber: @rjg
I can confirm this issue. It seems this needs adjustments in both
cube_project_exec
anduvedit_unwrap_cube_project
.When the
cube_size
is determined based on thebounds
it shouldn't usecube_size = cube_size ? 2.0f / cube_size : 1.0f;
incube_project_exec
. Instead thecube_size
should be used as is (or set to1.0f
if zero).The
shouldn't need to multiply thecube_size
with a0.5f
factor anymore.@rjg
Hi,
any reason this was not addressed and made it into final 2.92?
@Rawalanche Nobody wrote a patch for it between the confirmation of the bug (Feb 5) and release of 2.92 (Feb 25).
I was really confused mainly because right in the post above mine it seemed like you already had a solution, knew exactly what needs to be done, and at the same time it was reported three weeks before release, so time should be there. So I thought there was some deeper dependency on something else preventing this from being addressed.
@Rawalanche No hidden surprise so far. Since the beginning of February I'm no longer working part-time on the bug tracker , because I have to finish my computer science degree. Thus I have limited time available to write patches and help with bug triaging.
This issue was referenced by
8810d0cecd
It doesn't appear that https://developer.blender.org/rB8810d0cecdd5c192d0562c62490695d22ca684d5 fixed anything. Applying a cube projection of a size of 2 onto a 2x2x2 cube with 1.0 scale will still result in cubic mapping of size 1:
The fix either did not make it into the main branch or it's a placebo.
