Import scripts for MilkShape3D file formats
Closed, ArchivedPublicPATCH
Adds import scripts for MilkShape3D file formats. Both binary and ascii file formats are supported. All type of data is imported: mesh, materials, bones and even animation.
Including a test file to verify this actually works would be helpful.
Assigning to python expert :)
Committed with binary loader with minor changes and a fix for for faces that are ordered with the 3rd vert a zero index.
Ascii importer not commited, could you please provide an example for testing?
Here is a patch (ms3d_import_new.patch) that fixes a serious bug in the ms3d binary import script and adds support for weights. This patch can be commited now. I also added a simple example file (animated_cylinder.ms3d) what uses weights.
I will do the same fixes for the ascii import script and add an example file for that too, but that will a separate patch later. The ms3d_import_new.patch patch can be commited now.
applied ms3d_import_new.patch Revision: 15242
Here is a patch (ms3d_ascii_import.patch) that finally adds working MilkShape3D ascii file format import script to Blender.
I Also added a test file diablo.txt.
When the patch is commited this patch (#8540) can be closed.
glome - was there an export also? I could have sworn I saw one...
committed ascii importer.
thanks for the patch, closing.
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Unknown Status.Sep 23 2008, 2:50 AM
