Bug on depsgraph #85482
2 Participants
Reference: blender/blender#85482
Operating system: Windows 10
Graphics card: GTX1060 6GB
Blender 2.91
I think it is a bug in depsgraph causes the wrong result... Or I made some mistakes in using depsgraph
I am writing a function to convert a NURBS curve into a poly curve. Each edge has the same length along z-axis.
For example, the curve's z-dimension is 12 meters. The curve is composed of 11 points and 10 edges. pt0.z = 0, pt1.z = 1.2, pt3.z = 2.4, ..., pt11.z = 12.
I use bmesh.ops.bisect_plane to help me.
I attach the file with the script. If I run getUniformCurveOnZ alone in the script, it is OK. However, if I want to run getUniformCurveOnZ for different objects in one execution, I have a high chance to get the wrong result.
The number of control points in NURBS may influence the result.
The attached blend files, bugreport.blend includes the running result, while bugreportwithoutresult.blend doesn't.
Run the script directly in bugreportwithoutresult.blend to get the same result as shown inbugreport.blend.
Test one SpineCenterline works.
Test two SpineCenterlines give the wrong result.
You can copy my scripts and create your NURBS curves in your blender file. Just need to ensure the curve is not parallel to xy-plane.
One more thing, you can print the return vert at the end of getUniformCurveOnZ and after getUniformCurveOnZ. I don't know why they are different in SpineCenterline1.
Added subscriber: @WenyeHe
Added subscriber: @lichtwerk
Cannot reproduce here (tested in both 2.91 and current 2.93)
Always getting the (seemingly) correct result:
Just to make sure:
Does this mean sometimes results are correct, sometimes they are not?
