Geometry Nodes: Point Distribute Node - Density Max value #85585
7 Participants
Reference: blender/blender#85585
In Random mode, the Density Max socket suggests that this limits the maximum density.
However, multiplying the Density Attribute means that the Density Max can be overridden. It seems there is an assumption that the Density Attribute is likely to be a scalar value from a weight map in which case this would work.
Either this is a bug or it is by design.
If it is a bug then here is a suggested fix in the
sample_mesh_surface
function insource/blender/nodes/geometry/nodes/node_geo_point_distribute.cc
:const float v0_density_factor = std::max(0.0f, (*density_factors)[v0_index]);
change to
const float v0_density_factor = std::max(0.0f, std::min(base_density, (*density_factors)[v0_index]));
etc...Otherwise the socket should just be renamed to Density to avoid confusion.
Added subscriber: @CharlieJolly
Added subscriber: @victorlouis
I've asked something similar before in the chat, and I believe this is the intended behavior.
The
Density Attribute
is intended to function as an kind of mask that says: "here I want more stuff and here I want less stuff". TheDensity Max
was added to have a convenient slider in the node to tweak the density (by multiplying every density with this value).I think the name
Density Max
originated when it was assumed that theDensity Attribute
would be between 0 and 1. In that case, it would indeed be the maximum density. But because the density attribute can be > 1, it's somewhat of a misnomer. MaybeDensity Max
should be renamed toDensity Multiplier
?Added subscriber: @HooglyBoogly
Right, "Density Factor" might work too. "Max" is definitely misleading.
gn_weight_max.blend
File for testing, ignore messy nodes!
Please note how Density Max and Density Attribute affect the number of points in Random and Poisson Disk modes.
When the Density Attribute is in the range of 0-1, the Density Max setting works for both methods in a predictable way. Once the Density Attribute range is increased, there is a multiplication in the Random method and not the Poisson Disk method.
From a user perspective, the relationship should be the same for both methods.
Yellow Torus = Random; Green Cones = Poisson;
Density Max = 4; Density Attribute = 4; Total = 16;
Density Max = 16; Density Attribute = 1; Total = 16;
Density Max = 32; Density Attribute = 1; Total = 32;
Density Max = 8; Density Attribute = 4; Total = 32;
I've looked at the code to see why this happens. The reason is quite subtle, and I agree the behavior is inconsistent.
The random method calls
sample_mesh_surface
and passes thedensity_factors
. These two lines then determine the density:and
Note here that
looptri_density_factor
can be greater than 1, depending on the otherdensity_factors
. For the Poisson distribute method, this is different, thesample_mesh_surface
is also called, but without thedensity_factors
, and thus:The Poisson method uses the density_factors later in
update_elimination_mask_based_on_density_factors
, and there they are interpreted as probabilities, so they're effectively capped at 1:The easiest change to make both methods consistent, would be to calculate the
like this:This way, the
Density Attribute
is always interpreted as a mask with value between 0 and 1, but I'm not sure this is the behavior we want.Alternatively,
density_factors
could be passed tosample_mesh_surface
when using thepoisson
option and remove theupdate_elimination_mask_based_on_density_factors
function. In my tests this seems to work quite well but there maybe a good reason to use differentdensity_factors
for each distribution type.Change Poisson from:
To:
I asked @JacquesLucke about that before. That order is to provide stability in
id
attribute that this node generates.To test, add an attribute randomize node on the point's
radius
, try painting the density, transforming the mesh, or extruding some of the mesh's faces. Odds are changing the order makes one of those operations unstable.Added subscriber: @KenzieMac130
Added subscriber: @lichtwerk
Shall we confirm this for now?
Added subscriber: @SimonThommes
I think the behavior of being able to control the density with both inputs to a similar capacity without capping it is fine. But I do agree that the Naming should change. I think just using
Density
is totally fine even though it is more vague.Density Factor
is a bit misleading when no attribute is used.Changed status from 'Confirmed' to: 'Resolved'
The node is deprecated and the Distribute Points on Faces node does not have the same problem.
