Attribute Processor for UX improvement #85655
17 Participants
Reference: blender/blender#85655
Plan of Attack
A new nodegroup type that supports attribute dataflow. This is added as a node and created from inside out (as oppose to the existing Node Group where you first group existing nodes).
Changes that affect other node groups as well:
{F9887618, size=full}
Background
While the attribute workflow is a powerful way to do complex operations, and its generality will make it useful in a lot of situations, but common feedback is that node trees will become very linear, because temporary values must be stored in attributes, rather than passed around with node links.
This is an example of a typical more complex attribute operation. While just a few attribute nodes are simple and easily readable, this sequence of nodes is hard to understand.
{F9805345, size=full}
Key Concepts
It has two different kinds of inputs: Group Inputs and Attributes Inputs (strings) - besides the Geometry It has no outputs - besides the Geometry
** When collapsed more attribute inputs can be visible (the ones not exposed).
When you add a new input attribute with the
button, the data type is chosen based on the data stored for "attribute search". After, you can adjust the input data type. I propose putting this option in a drop-down next to the attribute.** You can decide to expose the attribute as an input attribute visible/editable when the node is collapsed.
Added subscriber: @dfelinto
Attribute "Container" for simplified nodetrees for UX improvementsto Attribute "For Each Element Frame" for UX improvementAdded subscriber: @lone_noel
Added subscriber: @AndresStephens
Could be a nice replacement for groups, or to add this kind of IN/OUT nodes inside of groups, but I don't think it's a good alternative to what groups provide. Though for looping structures, this would make sense.
Added subscriber: @MiroHorvath
Added subscriber: @CharlieJolly
The For Each Element Frame title suggests looping but I'm not clear if this task is suggesting it is for looping or not. Can this be clarified or will that be another task?
This isn't about looping. It's about using a different evaluation method to change attributes on a geometry.
Added subscriber: @KenzieMac130
How about the name along the lines of "Attribute Processor"? Since the user is designing a network which processes attributes in a sandboxed environment.
I think this name also adapts well if the process was done in parallel since a "for loop" concept might make the user expect or want some sort of feedback from a "previous itteration" which in this case cannot be guaranteed.
I like that name a lot, thanks!
Attribute "For Each Element Frame" for UX improvementto Attribute Processor for UX improvementAdded subscriber: @brecht
This seems quite similar to what we need for new texture nodes #54656 (Cycles/Eevee texture nodes for modifiers, painting and more). I imagine you'd want to be able to access the same kinds of texture nodes, color ramps, etc here too. The big difference being that in this attribute processor design the attributes are passed in explicitly, whereas in texture nodes they are brought in through nodes, either explicitly by name or automatically by some node types. So hopefully both systems can shared a lot of code in the end or even converge to the same thing.
An alternative would be to support evaluating expressions. Again not quite the same since they only evaluate to a single value and the UI is quite different, but in many cases it's a solution to the same problem. We already have an implementation for drivers:
https://developer.blender.org/diffusion/B/browse/master/source/blender/blenlib/BLI_expr_pylike_eval.h
Right, I believe Jacques has been talking about expression node for a while. Personally I would strongly prefer to prioritize a node-based approach first.
It's a bit silly, but a texture fits surprisingly well into the idea of geometry component attributes. So I expect it wouldn't be too hard to share code, it should just be a matter of gathering the input and output arrays and making sure the relevant nodes have a multi-function implementation.
I think it should be relatively straight forward to use some node groups in shading and geometry nodes (and possibly other contexts). Obviously, only a subset of the available nodes can be used in such node groups.
The Attribute Processor design mockups are mostly just syntactic sugar for the geometry nodes context imo. The same functionality could be achieved without introducing new ui concepts. E.g. one could just have a different kind of Group node (which is similar to what I did in Animation Nodes, given that I couldn't introduce new ui concepts there).
Added subscriber: @hadrien
I'm not sure why a new UI is necessary since this seems to cover exactly what node groups do ? Is the idea to communicate to the user that they are working in a special sandbox and only certain nodes are allowed ?(as opposed to a regular node group which has no such limitations)
Apart from that you have my blessing. I've also started finding long string of attribute nodes unnecessarily difficult to read.
With the introduction of this attribute processor, would attribute-specific nodes still be necessary ? (attribute color ramp, etc) Would they keep existing alongside the attribute processor ?
I feel like the already existing attribute nodes can stay since they are useful in a pinch when you want to just do a simple operation or two (maybe the attribute texture would need to eventually be depreciated and moved to a processor when the blender internal textures are finally removed). Aside from that there would likely need to be other attribute management nodes (like delete, set defaults, and rename) that wouldn't fit well in the attribute processor design.
@brecht is the idea for texture nodesfor them to be part of the material nodetree? as a special "custom texture" node?
I think it's effectively a node group with an arbitrary number of inputs and outputs, that supports a subset of all shader nodes and can be created or used outside of materials. So it would be integrated the same as a shader node group, but with naming / icons / coloring to distinguish it.
Added subscriber: @RC12
Added subscriber: @Erindale
Added subscriber: @lateasusual
Added subscriber: @IyadAhmed
Here are a few thoughts on the interface side of this:
Added subscriber: @BartekMoniewski
Added subscriber: @karmaral
Added subscriber: @satishgoda1
For the records, I removed these mockups since they are outdated. I also removed any reference to layout since this behaves more like a node group.
"The same behavior can be basically recreated with non-attribute nodes executed per every element. Here is a rough mockup of that same node tree with parallel evaluation:"
"And a different take on visuals by @lone_noel:"
Updated the task with the discussions the node group team had today. I added the following:
Plan of Attack
(Edit: Upon further inspection of the mockup it seems the potential issue was already accounted for)
Added subscriber: @CreatorSiSo
I think the best way of doing this is actually to introduce the attribute prozzesor node which allows you to select a attribute nodes graph like for a group node (but just with this graph type) and then opening the graph via TAB in a completely new nodes editor (no transperancy like in a group node). This is also how i would structure everything nodes in general because it just makes sence to dive deeper into the Objects/Geometry/Attributes for all of the little parts you want add to something (also its probably best way to do iterational and more complex stuff like bluring and so on in a place with a lot of space and not inside a frame inside the geometry nodes
not like this:
Also the other nodes that use should obviosly stay because they are used to manipulate the geometry with attributes and the attribute nodes would be uses to make changes to one or multiple attributes.
