Attribute Convert node #85700
Reference: blender/blender#85700
This node converts an existing attribute to a new type (possibly overwriting the existing attribute).
Inputs
Properties
Outputs
Added subscribers: @JacquesLucke, @HooglyBoogly
Added subscriber: @dfelinto
"Attribute Copy" might actually be a better name, since it doesn't necessarily remove the original attribute.
And yes, destination domain would make sense as well.
The use case here is to solve a problem we're having exposing the material index attribute, where the attribute math nodes all work on float data types, but material index is an integer attribute.
Added subscriber: @CharlieJolly
I started to put together a patch for this but it would be helpful if the team could provide a sample file where this would be useful.
Awesome! One example is the material index node, it would let you use a float attribute from attribute math nodes for the material.
Another is converting an attribute from the attribute math nodes to an existing UV Map attribute. For that you may need the domain drop-down though.
WIP Geometry Nodes: Add Attribute Convert node here: D10624
Just assigning Charlie here since there is already a patch in progress for this.
@HooglyBoogly I read your comments on the patch:
Just to clarify:
Auto - Convert Attribute to Result using the source domain as the destination.
Otherwise, convert Attribute to Result using the chosen Domain as the destination.
