Adjust Last Operation panel is slow (some Undo/Redo happening?)
Closed, ResolvedPublicBUG
Graphics card: GeForce GTX 950M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 398.35
Broken: version: 2.92.0 Alpha, branch: master, commit date: 2021-01-07 22:28, hash: rB61f1faac3f21
In scenes with visible or invisible objects with modifiers, the options menu freeze
Windows, 2.92 (can't use 2.93 or higher) can confirm.
For test file in header (the 2MB one), I can't see any problem with 2.92 or 2.90.0. But 2.83.16 I see slowdown.
Test file (the 26MB one) have problem but not easy to catch at first. How I got it to "work":
  1. Open file
  2. Delete visible sphere
  3. Add another UV sphere
  4. Delete it
  5. Add yet another UV sphere
  6. Change anything via last operation menu and see slowdown
For this bug you only need text object with his modifiers. In 2.83.16 you don't need those steps to reproduce, it's always laggy.
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Needs Information from User.Feb 18 2021, 3:19 PM
I cannot reproduce this with either the latest stable or current development versions of Blender.
Please try the latest daily build: https://builder.blender.org/download/
Go to File → Defaults → Load Factory Settings and then load your file to see if you still can reproduce this issue.
If the problem persists, please give us more clear instructions on how to reproduce it from scratch.
Cannot reproduce here
**System Information**
Operating system: Linux-5.10.12-200.fc33.x86_64-x86_64-with-fedora-33-Thirty_Three 64 Bits
Graphics card: GeForce GTX 970M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 455.45.01
version: 2.93.0 Alpha, branch: master, commit date: 2021-02-07 23:21, hash: `rBeb7d9e2a1bba`
I assume you have checked the lastest builds from https://builder.blender.org/download/?
Please try with File → Defaults → Load Factory Settings to see if you still can reproduce this issue.
Download new 2.93 - same problem. Do you open attach file?
In new scene this problem can't reproduce, but in large or in the scene with Remesh modifier freezes begin
Try in this scene create a sphere and change parameters.
I am seeing the same as @Germano Cavalcante (mano-wii) (no issues afaict)
Test please this file
Philipp Oeser (lichtwerk) changed the task status from Needs Information from User to Needs Triage.Feb 28 2021, 8:44 AM
I can't reproduce the problem with the new file either.
It is possible that an addon is causing this.
Try with the factory settings (File → Defaults → Load Factory Settings)
It's with factory settings!
Try to run blender_debug-gpu.cmd that is included in the download.
Replicate the problem quickly and then close Blender.
After Blender closes, the logs will be in a text file which can be attached here.
Most likely it will contain more information about the error.
It would be good to redo the tests with factory settings.
Some addons interfered with the results.
uvpackmaster2 for example was not un-registered correctly.
DreamUV-master showed some warnings.
It is interesting to note that there is a space between each message of redo_cb: operator redo Add UV Sphere.
The expected would be something like this:
Unfortunately I still don't think there is enough to identify the cause of the problem.
Try to run blender_debug_log.cmd, it might show something more informative.
Can't redo on 2.92, 2.93. On 3.0, there's an use after free issue:
Can not reproduce either.
@Philipp Oeser (lichtwerk) , Better we tag this as Unconfirmed because no one is able to replicate the issue so far :)
For test file in header, I can't see any problem with 2.92 or 2.90.0. But 2.83.16 I see slowdown.
Test file in comments have problem but not easy to catch at first. How I got it to "work":
  1. Open file
  4. Delete it
  1. Open file
  4. Delete it
I can repro with these steps.
Philipp Oeser (lichtwerk) added a project: Restricted Project.Jun 25 2021, 12:20 PM
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.Jun 25 2021, 12:23 PM
Philipp Oeser (lichtwerk) updated the task description. (Show Details)
Though not really doing anything outside the Adjust Last operation panel in between, T78171: Adjust Last Operation: Other changes outside that panel are reverted back automatically might be related in a way.
Philipp Oeser (lichtwerk) renamed this task from Freeze option menu to Adjust Last Operation panel is slow (some Undo/Redo happening?).Jun 25 2021, 2:08 PM
Bastien Montagne (mont29) changed the subtype of this task from "Report" to "Bug".Apr 14 2022, 12:16 PM
Slow down comes from re-evaluation of some heavy Decimate modifier in unrelated objects...
While at step 3 (first adding of new UVSphere) the METext meshes are just re-used as-is during undo/redo, after the second addition of another UVSphere they are re-read in-place, which forces the depsgraph to re-evaluate them (including their very expensive Decimate modifier).
Still investigating about why those meshes are detected as changed in the latest case.
Bastien Montagne (mont29) moved this task from Backlog to Bugs on the Core board.Apr 14 2022, 12:16 PM
This is actually a beautiful bug hidden deep inside the memfile undo step writing code... Took me a while to fully understand the issue. Fix incoming.
In a nutshell, the issue is reproducible when a new ID is added, which is smaller in memory than the one following it. Then is would cause said following ID to be falsely identified as changed (because the initial memory reference_current_chunk for the following ID would not be the first one in the existing, previously written undo step), leading to it being fully re-read and re-evaluated on undo.
In that file, the first added UVSphere creates a MESphere.002 ID that comes before existing MESphere.002 one, which is fine (MESphere.002 being small enough to not trigger the issue). However, second addition of UVSphere creates MESphere.004, which comes before METext, a much, much bigger mesh.
Since MESphere.004 is new, there is no matching existing memchunk, but we still keep iterating over the list of existing memchunk while writing new ones for the new mesh, which lives us 'somewhere' inside of memchunks for METext when we start writing this one. Existing code would then wrongly assume current reference memchunk is good, when we actually want to start writing an ID on the very first reference memchunk matching it, not somewhere in the middle...
