Cycles hybrid rendering + OIDN not detecting correct number of threads
Confirmed, NormalPublic
Operating system: Linux-5.8.0-7642-generic-x86_64-with-glibc2.32 64 Bits
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 460.39
Broken: version: 2.93.0 Alpha, branch: master, commit date: 2021-02-18 19:59, hash: rB27fd066baf55
When using cycles hybrid rendering (CPU+GPU) + Open Image Denoise, the number of rendering buckets should be equal to the number of threads in the CPU. This is n-1 for CPU and 1 thread reserved for the GPU (Confirmed by Lord @Brecht Van Lommel (brecht))
Instead of using the number of available threads, only the number of available cores is used.
For example, in a 6 Core/12 Thread i7 + GPU configuration, we get 6 rendering buckets instead of 12 (11 CPU + 1 GPU).
Or, in a 4 Core/8 Thread i7 + GPU configuration, we get 4 rendering buckets instead of 8 (7 CPU + 1 GPU)
Disable OID and it goes back to normal.
Tested using CUDA on Linux and Windows
Alaska (Alaska) changed the task status from Needs Triage to Needs Information from User.Feb 19 2021, 6:58 AM
Alaska (Alaska) added a subscriber: Alaska (Alaska).
Just wanted to add that I was personally unable to replicate this issue with:
System Information:
Operating system: Linux-5.10.0-3-amd64-x86_64-with-glibc2.31 64 Bits
Graphics card: GeForce RTX 3070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 460.39
Central Processing Unit: Ryzen 9 5950X
Blender Version:
with CUDA or OptiX.
@Daniel Salazar (zanqdo), it's possible something may be wrong the build of Blender you have (or there may be an "issue" with the build of Blender I have), are you able to test with a Blender version downloaded from https://builder.blender.org/download/ if you haven't already?
It's also possible you may have some add-ons installed that are affecting this? Maybe try disabling all add-ons by loading factory defaults (Located in the menu File -> Defaults -> Load Factory Defaults), then configuring your GPU+CPU setup in settings, then rendering and seeing if that fixes it?
Another possible contributor could be the .blend file. Inspect the Performance tab in the Render properties panel and make sure the Threads Mode is set to Auto.
And I know this is a huge stretch, but it could be possible that you have hyperthreading disabled in the BIOS? It's also possible some other external application like "Thread Lasso" is affecting things, however that doesn't explain why it occurs on multiple OS.
I'm sorry, I'm just throwing ideas at the wall for why you may be experiencing this issue and seeing if any of them help.
The windows build is indeed downloaded from the builder.
Also Auto detection is set and it detects correctly: 12 in the Linux box and 8 in the Windows box.
When I switch to CPU mode, it will use all available threads.
I've also tested on factory defaults :)
Maybe it's an Intel only problem?
I really have no clue, and sadly I don't have an Intel CPU to test with. Will probably have to wait for others to report in on the issue.
In the meantime, are you able to run Blender with the debugger for Cycles? Here's how to do it on Linux:
  1. In the terminal run the command "/path/to/blender" --debug-cycles then go to a scene and render with CPU+GPU.
  2. After the scene has rendered for a few seconds, go back to the terminal and copy the output to a text file and upload it here. The most important part is probably the beginning, here's the beginning of mine:
I0219 22:26:26.839707 13939 blender_python.cpp:194] Debug flags initialized to:
CPU flags:
  AVX2       : True
  AVX        : True
  SSE4.1     : True
  SSE3       : True
  SSE2       : True
  BVH layout : EMBREE
  Split      : False
CUDA flags:
  Adaptive Compile : False
OptiX flags:
  CUDA streams : 1
OpenCL flags:
  Device type    : ALL
  Debug          : False
  Memory limit   : 0
I0219 22:26:33.289114 13939 device_cuda.cpp:41] CUEW initialization succeeded
I0219 22:26:33.289153 13939 device_cuda.cpp:43] Found precompiled kernels
I0219 22:26:33.360615 13939 device_cuda.cpp:176] Device has compute preemption or is not used for display.
I0219 22:26:33.360638 13939 device_cuda.cpp:179] Added device "GeForce RTX 3070" with id "CUDA_GeForce RTX 3070_0000:0a:00".
I0219 22:26:47.106143 14027 device.cpp:637] CPU render threads reduced from 32 to 31, to dedicate to GPU.
I0219 22:26:47.106189 14027 device_cpu.cpp:137] Will be using AVX2 kernels.
I0219 22:26:47.106487 14027 device_cuda_impl.cpp:714] Mapped host memory limit set to 29,382,348,800 bytes. (27.36G)
I0219 22:26:47.238039 14027 device.cpp:637] CPU render threads reduced from 32 to 31, to dedicate to GPU.
I0219 22:26:47.238111 14027 device.cpp:637] CPU render threads reduced from 32 to 31, to dedicate to GPU.
I0219 22:26:47.238687 14027 blender_sync.cpp:254] Total time spent synchronizing data: 0.000267982
In here you can see messages saying CPU render threads reduced from 32 to 31, to dedicate to GPU. Your Blender may be dedicating more threads to GPU than expected? Not sure.
I'm sorry, I'm not a developer and I actually don't know enough about Blender to properly look into this, I'm just trying to gather information so when a developer does look into it, they can quickly rule out somethings.
It's also implied that you are building Blender from source code on your Linux machine. If so, it may be possible to bisect the exact commit that causes the issue for you.
But first, you should make sure that it is caused by a recent change in Blender. The easiest way is to download Blender 2.91.2 or 2.83.X and test with that. https://www.blender.org/download/
If those versions of Blender aren't working, then it's possibly something wrong with your system? Have a look into doing a clean OS install and such?
If those versions of Blender are working as expected, then you can go onto finding the commit that's causing the issue for you. This can be done by bisecting.
Simple instructions are given for bisecting in the triaging playbook:
git bisect start
git bisect bad HEAD
git bisect good "GOOD-COMMIT"
For questions and assistance with that, check #blender-coders on blender.chat and point anyone to this reply.
Or I may be able to offer assistance.
Do they render with the Open image Denoise?
That's what I had the problem with. It was rendered with only half as many threads as possible. But with the CPU everything worked. Problem solution was the Denoise Node in the Compositor.
Alaska (Alaska) added a comment.EditedFeb 19 2021, 9:04 PM
I can confirm what @Effi (BlenderEffi) said, enabling Open Image Denoise in the render settings limits threads to half that of the CPU when rendering with GPU compute or hybrid rendering.
@Daniel Salazar (zanqdo) can you confirm this?
If this is the issue you're experiencing, then this seems to be expected? In this file (https://developer.blender.org/diffusion/B/browse/master/intern/cycles/blender/blender_sync.cpp$904) there is a comment that explains that Blender should Add additional denoising devices if we are rendering and denoising with different devices. Which probably includes adding half the thread count to denoising when rendering with a different device (E.G. GPU compute, even if it includes CPU via hybrid rendering).
OMG That was it! Is this intentional?
This totally kills the performance without the user having any clue of the cause.
Daniel Salazar (zanqdo) renamed this task from Cycles hybrid rendering not detecting correct number of threads to Cycles hybrid rendering + OID not detecting correct number of threads.Feb 19 2021, 9:11 PM
Daniel Salazar (zanqdo) updated the task description. (Show Details)
Evan Wilson (EAW) renamed this task from Cycles hybrid rendering + OID not detecting correct number of threads to Cycles hybrid rendering + OIDN not detecting correct number of threads.Feb 22 2021, 8:22 PM
Philipp Oeser (lichtwerk) changed the task status from Needs Information from User to Confirmed.Mar 24 2021, 2:11 PM
Also seeing this.
Not totally sure if this has an underlying reason, but if so, should be reflected in the UI somehow I guess.
Getting the same problem. Tried forcing more threads manually but it didn't work. Same bevaviour using the number of cores and not the number of threads.
