Sequencer : Cross Fade between adjustement layer strips not working since 2.9
Needs Triage, NormalPublic
Operating system: Linux
Graphics card: NVIDIA GTX 560 Ti
Broken: from 2.90.0 to 2.91.2
Worked: 2.83.12
In the sequencer, a simple cross fade (cross or gamma cross) beteween two adjustement layer strip doesn't work since Blender 2.90.0.
in the sequencer, add two images separated by some empty frames, add ajustement layer on top of them and cross fade the two AL strips. The attached file work with 2.83.* (replace both images by the first you find - obviously, in true workflow, I use this functionality with more complex stacked strips...).
Yohan Le Diraison (YohanLeDiraison) renamed this task from Sequencer : Cross Fade between Adjustement layer not working since 2.9 to Sequencer : Cross Fade between adjustement layer strip not working since 2.9.Sat, Feb 20, 6:53 PM
Yohan Le Diraison (YohanLeDiraison) renamed this task from Sequencer : Cross Fade between adjustement layer strip not working since 2.9 to Sequencer : Cross Fade between adjustement layer strips not working since 2.9.Sat, Feb 20, 6:55 PM
