Geometry Nodes: Writing an attribute of type 'color' directly to the position attribute has no effect. #85864
5 Participants
Reference: blender/blender#85864
Operating system: Darwin-18.7.0-x86_64-i386-64bit 64 Bits
Graphics card: Intel Iris OpenGL Engine Intel Inc. 4.1 INTEL-12.10.16
Broken: version: 2.93.0 Alpha, branch: master, commit date: 2021-02-21 23:22, hash:
af940c68cb
Writing to the position attribute doesn't work when using an attribute of type 'color'.
This means: Directly writing the output of the Attribute Sample Texture node to the position attribute or mixing colors with the Attribute Mix node with the result set to "position" has no effect.
Both cases work for the rotation and scale attributes.
Explicitly converting the color attribute to a vector attribute first using a Vector Math Node works as expected.
position-attribute-bug.mp4
From startup file:
From the .blend-file in the video:
sample-texture-position-bug.blend
Added subscriber: @lone_noel
Thanks for the report and the clear test file. This is likely a known issue at the moment, but I think we should address it.
The difference here is that
position
is the only built-in attribute, so its type can not be changed.For the others, (
scale
,rotation
), AFAIK they are actually created with a color data type, but since there is implicit conversion back to float, you don't notice it.I think this comes down to how we've implemented the data type conversion for writing to an attribute's values. It always uses the new type by removing the old attribute and creating a new one.
I think there are many cases where we'd want to use interpolation instead. Built-in attributes are the most obvious case of course, but there may be others.
Not sure if that makes sense, but I wanted to write it down somewhere anyway.
I see, that's good to know. Thanks for the insight!
Added subscriber: @CharlieJolly
In this case, could there be an implicit conversion of rgb(-a) to position when using this node and add a node warning that there is potential data loss.
In future there could be a node to convert color4f to float3 with options on how to handle the alpha value or this could be added to any node that handles color.
Closed as duplicate of #86633
Added subscriber: @Faster
This comment was removed by @Faster
