Blnder crashes when i open it #85888
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#85888
Operating system:
Graphics card: AMD Radeon graphics processor
(example: 2.79b release)
When I try to open blender it crashes. I've already tried to do it from Steam, with my drivers experimental and updated. I find it strange that I can not run it since before the computer was formatted, it did it perfectly.
Added subscriber: @IvanJamesGalaxey
Added subscriber: @rjg
Unfortunately your report is missing important information like your operating system, specific GPU model and graphics driver.
If you are using Windows, open Blender's installation directory and double click on the
blender_debug_gpu.cmd
. This will start Blender in debug mode and create log files. Try to make Blender crash again. Once it crashes the Windows Explorer should open and show you up to two files, a debug log and the system information. Add them to your bug report by clicking on the upload button as shown in the screenshot below or via drag and drop. Please also upload the crash log located inC:\Users\[your username]\AppData\Local\Temp\[project name].crash.txt
(or simply type%TEMP%
into the path bar of the Windows Explorer).blender_debug_output.txt And about the %TEMP% there are many files, i don't know which one. I'm on windows 10, I have an Intel(R) Core(TM) it CPU
@IvanJamesGalaxey The file we need is
C:\Users\vicog\AppData\Local\Temp\blender.crash.txt
and please check for the exact GPU model in your computer and add it to your report. From the debug log it seems to crash in your graphics driver.blender.crash.txt. My GPU is and I've already updated and reinstalled my graphic drivers
The [AMD HD 5000 series ]] has the old TeraScale 2 micro-architecture. The https:*www.blender.org/download/requirements/ for Blender 2.8x and 2.9x state that [ https://en.wikipedia.org/wiki/List_of_AMD_graphics_processing_units#Features_Overview | GCN first generation or later is required for running Blender.
Unfortunately, this means that your GPU is below the minimum requirements and we don't provide support for it. Graphics glitches and even crashes due to unpatched bugs in the graphics driver can occur on unsupported hardware.
There was an issue with unsupported GPUs that the upcoming Blender 2.92 will include a workaround for (see D9667). You can enable the workaround in earlier versions by opening Blender's installation directory and double-clicking on the
blender_debug_gpu_glitchworkaround.cmd
. [Daily builds of Blender 2.92 ]], which is currently still in development, are available for testing. If neither of them work you will have to use a [ https:*download.blender.org/release/ | previous release of Blender with lower requirements.Please create a new report in case the issue is also happening on a system that fulfills the minimum requirements and uses a current graphics driver.
blender_debug_gpu_glitchworkaround.cmd works, merci Robert
