Compund_Collision_chain demo not working properly #85932
6 Participants
Reference: blender/blender#85932
Operating system: Linux-5.4.0-65-generic-x86_64-with-debian-bullseye-sid 64 Bits
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 460.32.03
Broken: version: 2.92.0 Release Candidate, branch: master, commit date: 2021-02-22 12:21, hash:
e497c1b93c
The demo file Compund_Collision_chain that can be downloaded from https://www.blender.org/download/demo-files/ it doesn't seem to be working properly
1- Download the file compound_collision_chain.blend from https://www.blender.org/download/demo-files/
2-in the properties tab "scene properties" delete the bake for the rigid bodies
3- Probably after deleting the bake the baked keyframes are still in ram if you did playback before deleting the cache, add a keyframe to the position of the first chain link just to force blender to dump the cache.
4- This should happend if you bake again or try to playback the animation puff.mp4
Added subscriber: @NahuelBelich
Added subscribers: @ZedDB, @lichtwerk
Can confirm.
@ZedDB : does this ring a bell?
Seems like something is wrong with the hosted test file!
If you use the original file from the patch, it works: https://developer.blender.org/D5797
I've have seen this issue before and it seems like the bullet physics world has somehow gotten into an invalid state.
So no matter what you do, things will explode and get "ghost" forces applied to them.
Previously I had to delete the rigidbody physics world and start over in the file to fix this.
I don't know why or how this happens, perhaps it has to do with compression as the original example file is ~6mb while the newer broken one is ~800kb...
@NahuelBelich can you see if you can reproduce the issue by starting with the original working file and then try to make it break like in the new example file?
I'm guessing it is related to saving and loading the file.
@ZedDB ill try tonight and let you know
@NahuelBelich Great!
Note the I have never myself been able to reproduce broken files it is only from bug reports that I have gotten them.
So if you could figure out how to break it that would be super!
@ZedDB
This is becoming a bit weirder than my artist brain can understand, first the tests.
Blend file "Comptest Chain Original.blend" From https://developer.blender.org/D5797
2.91.2 : Works fine
2.92 candidate : Works fine
2.93 alpha : Works fine
Blend File "compound_collision_chain.blend" from https://www.blender.org/download/demo-files/
2.91.2 : fails
2.92 Candidate : fails
2.93 alpha : fails
This is the weirdest part, i though that some property could be different between objets in the files and the properties looks all the same, then i though may be the compress option for the blend file, didn't change anything, then i try this.
In the old demo the one that weights 6mb
1 - select a few links of the chain
2- move it a bit to one side
3- Ctrl+c to copy
4- Ctrl+v to paste the object in a new empty blend file
did the same with the file hosted in blender.org the one that weights 769 Kb, move the chains same way but to the other side, shoud look the same under a new empty blender but. .
Chains demo.blend
asdasdad.mp4
as you can see the chains looks very different, the one on the right from the hosted blender.org file, twists into itself in a really weird way.
i check the objetcs one by one and the rigid bodies properties are the same at least in the interface that i can see, should look the same but it does not.
I made a test from scratch, I made new objects in a new file and copy all the parameters by hand for the rigid body from+ the chain in the hosted blender.org file, the ones that looks bad in the video above, and it works as a charm in this new file.
chain from scratch.blend
aaaaa.mp4
i wasn't able to crash the original file, save with compression with out compression, baked, no baked, not sure whats happening but as it looks what its breaking things can be copy with the objects if you copy objects from blend to blend.
Added subscriber: @Fernando-Alcala
David's original scene Comptest Chain.blend (6mb) used three separate cubes each with a convex hull. This one works.
Then Dalai did some "cleanup" compound_collision_chain.blend (777kb) and merged those cubes, creating a concave shape that still has convex hull. This is what you download off of Blender. Doesn't work.
David then fixes this compound_collision_chain.blend (253kb) by separating the bottom cube and removing the rigid bodies from the wall.
David explains this in the last comment of that thread.
As for the chain behaving differently, I also couldn't find anything different. Same numbers, same parenting, same orientation, same structure, but obviously something happened. What you can see is that only two links of the top chain seem to be different. 2021-02-25 13-34-10.mp4
@Fernando-Alcala what thread are you talking about here. I'm a bit lost at it seems like you are quoting a forum thread but not linking to it.
D5797#237065 comment section?
Added subscribers: @sreich, @dfelinto
Thanks for the report. Marking this as known issue since it depends on the rigid body system which at the moment has no active developer. I'm tagging Sergej here anyways in case he wants to tackle any of those. Anyone wlse interested on that can also join the geometry nodes meetings to get onboarded.
@dfelinto This is not a know issue.
This is not a problem with the simulation code at all.
The issue here is that you did some cleanup of the test file that broke it.
To unbreak it, we should replace the current file we host with the original file that was provided to us.
If it's not a known issue then I assume it can be classified as a bug? The idea was to complete the triaging process and be realistic about our ability to fix many of these reports.
Got it. I don't know what, but I just did just some minor cleanups and re-uploaded the file to the same place. If it doesn't work let me know. (this time I even uploaded the file un-baked)
Seems to be working now, thanks! :)
