Object masking via Boolean Difference leads to damaged object. #85933
Reference: blender/blender#85933
Operating system: Windows 10
Graphics card: Nvidia GeForce GTX 750
Broken: 2.91.2 2021-01-19 16:15 Hash
5be9ef4177
Worked: ..
Boolean function "Difference" not working correctly, regardless if done in Blender with CTRL + Minus or via BoolTool
All objects have the Scale applied, in order to avoid any scaling problems
3.a. Laser_red without masking. Laser_red directly perpendicular to cylnder bar
3.b. Laser_blue with masking object "Mask_cube_blue", to hide laser beams behind bar. Laser_blue directly perpendicular to cylnder bar
3.c. Laser_green with masking obejct "Mask_cube_green" behind cylinder ba, like 3.b. The laser_green, though, is slightly rotated. Additionally, array Modifier was applied.
In Laser_blue, 1 laser beam is missing.
In Laser_Green, many laser beams are missing.
Laser_beams.blend
Added subscriber: @dan.rockstreet
Added subscriber: @deadpin
It looks like enabling the
Self
option for the booleans allows much better results in both cases. However, it causes a great increase in processing time.The issue is probably due to a lot of overlapping "blades" of the lasers, not the boolean object per-se:
Added subscriber: @filedescriptor
I cannot reproduce this on the latest 2.93.0 Alpha, branch: master, commit date: 2021-02-24 05:16, hash:
8d50a3e19e
.It seems that the beta still has this issue, although, as @deadpin mentioned, you could use the
Self
option to solve this.~~Could you try the latest alpha from https://builder.blender.org/download/? ~~
EDIT: I just noticed that the alpha version also removes some beams, but different ones. Using
Self
works though.Hi Jesse/David
thanks for spending time on answering.
Using "Self" works indeed, but in my system with GTX 750 it gets so very slow... also in 2.93.0 alpha
Impossible to use in a live presentation where I can check if the laser beams are safe or not in certain situations.
I tested with the Solver set to "Fast" instead of "Exact" and it works - all beams are now viewable. Probably this is the opposite of what to expect between Fastand Exact;-)
Will close this for now as it seems to work properly with "Self". Feel free to open a new report if you have any other issues.
