The design is T85654
Mockups by @Pablo Vazquez (pablovazquez)
I apologize in advance if this is not the right task to comment about it, but as I see the Display menu here I gotta ask, would it be possible to have a check box to see position attributes in world(global) coordinates, please?
Simplified version for the list of filtering rules. No expressions nor conditional operators yet.
Each rule is represented by a collapsable box. The modifiers/panels layout could be used to achieve the collapsing behavior, although dragging/ordering is not necessary (initially), so it's not included in the mockup. An X lets you remove the rule.
Based on the idea by @Máté Kerekes (elfoglalt) of using a similar layout to modifiers but I've removed superfluous functionality.
Perfect, @Jacques Lucke (JacquesLucke) @Hans Goudey (HooglyBoogly) just remember that on top of that if the column is not available we should see it red somehow.
Also the mockup is using position.y and position[y] but we should match the column name with the rules column field. Right now that means position Y`.
As a separate topic (not for this task) we should indeed talk about how to represent vector individual components in the spreadsheet (the other alternative is position[0]). This is assuming we will support this in the nodetree as well,
if not what we have is fine (position X).
To move the other mockups to https://wiki.blender.org/wiki/Source/Editors/Spreadsheet
