Not relevant, occurs on Linux and Windows and regardless of GPU hardware.
Broken:
- 2.93.0 Alpha, branch: master, commit date: 2021-03-09 16:42, hash: rBb1ef55abdbb9
- 2.92.0 stable
- 2.91.2, branch: master, commit date: 2021-01-19 16:15, hash: rB5be9ef417703
Worked:
- Unknown
As the topic described, I tested bezier curve and it works fine.
- Add > Curve > Path.
- Switch to edit mode and deselect everything (Alt+A).
- Use Ctrl+RMB and press into the void of the 3D view for at least three times.
Blender should either crash or produce visual artifacts where parts of the curve appear to extend to infinity.
ASAN report for 2.93.0 Alpha, branch: master, commit date: 2021-03-09 16:42, hash: rBb1ef55abdbb9
==3501==ERROR: AddressSanitizer: heap-buffer-overflow on address 0x6020002e3a78 at pc 0x00000365f400 bp 0x7fffffffc730 sp 0x7fffffffc720 READ of size 4 at 0x6020002e3a78 thread T0 #0 0x365f3ff in copy_v3_v3 /home/dev/01-data/01-git/blender-git/blender/source/blender/blenlib/intern/math_vector_inline.c:62 #1 0x368d13b in BKE_curve_bevelList_make /home/dev/01-data/01-git/blender-git/blender/source/blender/blenkernel/intern/curve.c:2755 #2 0x4e12069 in do_makeDispListCurveTypes /home/dev/01-data/01-git/blender-git/blender/source/blender/blenkernel/intern/displist.c:1513 #3 0x4e165a0 in BKE_displist_make_curveTypes /home/dev/01-data/01-git/blender-git/blender/source/blender/blenkernel/intern/displist.c:1743 #4 0x3ab9dd0 in BKE_object_handle_data_update /home/dev/01-data/01-git/blender-git/blender/source/blender/blenkernel/intern/object_update.c:218 #5 0x3abc6db in BKE_object_eval_uber_data /home/dev/01-data/01-git/blender-git/blender/source/blender/blenkernel/intern/object_update.c:379 #6 0x18cfedd8 in operator() /home/dev/01-data/01-git/blender-git/blender/source/blender/depsgraph/intern/builder/deg_builder_nodes.cc:1351 #7 0x18d21c2b in _M_invoke /usr/include/c++/9/bits/std_function.h:300 #8 0x18c93eea in std::function<void (Depsgraph*)>::operator()(Depsgraph*) const /usr/include/c++/9/bits/std_function.h:688 #9 0x18c8f459 in evaluate_node /home/dev/01-data/01-git/blender-git/blender/source/blender/depsgraph/intern/eval/deg_eval.cc:113 #10 0x18c8f4a8 in deg_task_run_func /home/dev/01-data/01-git/blender-git/blender/source/blender/depsgraph/intern/eval/deg_eval.cc:124 #11 0x1a87029a in Task::operator()() const::{lambda()#1}::operator()() const /home/dev/01-data/01-git/blender-git/blender/source/blender/blenlib/intern/task_pool.cc:118 #12 0x1a87170d in tbb::interface7::internal::delegated_function<Task::operator()() const::{lambda()#1} const, void>::operator()() const /home/dev/01-data/01-git/blender-git/lib/linux_centos7_x86_64/tbb/include/tbb/task_arena.h:96 #13 0x5124424 in tbb::interface7::internal::isolate_within_arena(tbb::interface7::internal::delegate_base&, long) (/home/dev/01-data/01-git/blender-git/build_linux_debug_full/bin/blender+0x5124424) #14 0x1a87096a in void tbb::interface7::internal::isolate_impl<void, Task::operator()() const::{lambda()#1} const>(Task::operator()() const::{lambda()#1} const&) /home/dev/01-data/01-git/blender-git/lib/linux_centos7_x86_64/tbb/include/tbb/task_arena.h:216 #15 0x1a870614 in tbb::interface7::internal::return_type_or_void<Task::operator()() const::{lambda()#1}>::type tbb::interface7::this_task_arena::isolate<Task::operator()() const::{lambda()#1}>(tbb::interface7::internal::return_type_or_void const&) /home/dev/01-data/01-git/blender-git/lib/linux_centos7_x86_64/tbb/include/tbb/task_arena.h:472 #16 0x1a87036b in Task::operator()() const /home/dev/01-data/01-git/blender-git/blender/source/blender/blenlib/intern/task_pool.cc:118 #17 0x1a8715ad in tbb::internal::function_task<Task>::execute() /home/dev/01-data/01-git/blender-git/lib/linux_centos7_x86_64/tbb/include/tbb/task.h:1059 #18 0x5135284 in tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) (/home/dev/01-data/01-git/blender-git/build_linux_debug_full/bin/blender+0x5135284) #19 0x513553a in tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) (/home/dev/01-data/01-git/blender-git/build_linux_debug_full/bin/blender+0x513553a) #20 0x65b4f31 in tbb::task::wait_for_all() /home/dev/01-data/01-git/blender-git/lib/linux_centos7_x86_64/tbb/include/tbb/task.h:820 #21 0x65b6f2e in tbb::internal::task_group_base::wait() /home/dev/01-data/01-git/blender-git/lib/linux_centos7_x86_64/tbb/include/tbb/task_group.h:168 #22 0x1a86de69 in tbb_task_pool_work_and_wait /home/dev/01-data/01-git/blender-git/blender/source/blender/blenlib/intern/task_pool.cc:257 #23 0x1a86f3c7 in BLI_task_pool_work_and_wait /home/dev/01-data/01-git/blender-git/blender/source/blender/blenlib/intern/task_pool.cc:506 #24 0x18c91d91 in blender::deg::deg_evaluate_on_refresh(blender::deg::Depsgraph*) /home/dev/01-data/01-git/blender-git/blender/source/blender/depsgraph/intern/eval/deg_eval.cc:397 #25 0x18bae94e in deg_flush_updates_and_refresh /home/dev/01-data/01-git/blender-git/blender/source/blender/depsgraph/intern/depsgraph_eval.cc:58 #26 0x18baeade in DEG_evaluate_on_refresh /home/dev/01-data/01-git/blender-git/blender/source/blender/depsgraph/intern/depsgraph_eval.cc:73 #27 0x3cb394c in scene_graph_update_tagged /home/dev/01-data/01-git/blender-git/blender/source/blender/blenkernel/intern/scene.c:2641 #28 0x3cb3a50 in BKE_scene_graph_update_tagged /home/dev/01-data/01-git/blender-git/blender/source/blender/blenkernel/intern/scene.c:2680 #29 0x51557ca in wm_event_do_depsgraph /home/dev/01-data/01-git/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:387 #30 0x5155b38 in wm_event_do_refresh_wm_and_depsgraph /home/dev/01-data/01-git/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:412 #31 0x5158068 in wm_event_do_notifiers /home/dev/01-data/01-git/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:614 #32 0x5140f08 in WM_main /home/dev/01-data/01-git/blender-git/blender/source/blender/windowmanager/intern/wm.c:646 #33 0x35d7c9a in main /home/dev/01-data/01-git/blender-git/blender/source/creator/creator.c:520 #34 0x7ffff6e490b2 in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x270b2) #35 0x35d6e4d in _start (/home/dev/01-data/01-git/blender-git/build_linux_debug_full/bin/blender+0x35d6e4d) 0x6020002e3a78 is located 0 bytes to the right of 8-byte region [0x6020002e3a70,0x6020002e3a78) allocated by thread T0 here: #0 0x7ffff7690bc8 in malloc (/lib/x86_64-linux-gnu/libasan.so.5+0x10dbc8) #1 0x1a8afe20 in MEM_lockfree_mallocN /home/dev/01-data/01-git/blender-git/blender/intern/guardedalloc/intern/mallocn_lockfree_impl.c:276 #2 0x1a8b01c7 in MEM_lockfree_malloc_arrayN /home/dev/01-data/01-git/blender-git/blender/intern/guardedalloc/intern/mallocn_lockfree_impl.c:312 #3 0x366e743 in BKE_nurb_duplicate /home/dev/01-data/01-git/blender-git/blender/source/blender/blenkernel/intern/curve.c:689 #4 0x366f779 in BKE_nurbList_duplicate /home/dev/01-data/01-git/blender-git/blender/source/blender/blenkernel/intern/curve.c:743 #5 0x4e11ffc in do_makeDispListCurveTypes /home/dev/01-data/01-git/blender-git/blender/source/blender/blenkernel/intern/displist.c:1505 #6 0x4e165a0 in BKE_displist_make_curveTypes /home/dev/01-data/01-git/blender-git/blender/source/blender/blenkernel/intern/displist.c:1743 #7 0x3ab9dd0 in BKE_object_handle_data_update /home/dev/01-data/01-git/blender-git/blender/source/blender/blenkernel/intern/object_update.c:218 #8 0x3abc6db in BKE_object_eval_uber_data /home/dev/01-data/01-git/blender-git/blender/source/blender/blenkernel/intern/object_update.c:379 #9 0x18cfedd8 in operator() /home/dev/01-data/01-git/blender-git/blender/source/blender/depsgraph/intern/builder/deg_builder_nodes.cc:1351 #10 0x18d21c2b in _M_invoke /usr/include/c++/9/bits/std_function.h:300 #11 0x18c93eea in std::function<void (Depsgraph*)>::operator()(Depsgraph*) const /usr/include/c++/9/bits/std_function.h:688 #12 0x18c8f459 in evaluate_node /home/dev/01-data/01-git/blender-git/blender/source/blender/depsgraph/intern/eval/deg_eval.cc:113 #13 0x18c8f4a8 in deg_task_run_func /home/dev/01-data/01-git/blender-git/blender/source/blender/depsgraph/intern/eval/deg_eval.cc:124 #14 0x1a87029a in Task::operator()() const::{lambda()#1}::operator()() const /home/dev/01-data/01-git/blender-git/blender/source/blender/blenlib/intern/task_pool.cc:118 #15 0x1a87170d in tbb::interface7::internal::delegated_function<Task::operator()() const::{lambda()#1} const, void>::operator()() const /home/dev/01-data/01-git/blender-git/lib/linux_centos7_x86_64/tbb/include/tbb/task_arena.h:96 #16 0x5124424 in tbb::interface7::internal::isolate_within_arena(tbb::interface7::internal::delegate_base&, long) (/home/dev/01-data/01-git/blender-git/build_linux_debug_full/bin/blender+0x5124424) #17 0x7fffffffd1df ([stack]+0x201df) SUMMARY: AddressSanitizer: heap-buffer-overflow /home/dev/01-data/01-git/blender-git/blender/source/blender/blenlib/intern/math_vector_inline.c:62 in copy_v3_v3 Shadow bytes around the buggy address: 0x0c04800546f0: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa 0x0c0480054700: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa 0x0c0480054710: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa 0x0c0480054720: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa 0x0c0480054730: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa =>0x0c0480054740: fa fa fa fa fa fa fa fa fa fa fa fa fa fa 00[fa] 0x0c0480054750: fa fa 00 fa fa fa fd fd fa fa fd fd fa fa fd fd 0x0c0480054760: fa fa fd fa fa fa fd fd fa fa fd fd fa fa fd fd 0x0c0480054770: fa fa fd fd fa fa fd fd fa fa fd fa fa fa fd fd 0x0c0480054780: fa fa fd fa fa fa fd fd fa fa fd fd fa fa fd fd 0x0c0480054790: fa fa fd fd fa fa fd fd fa fa fd fa fa fa fd fd Shadow byte legend (one shadow byte represents 8 application bytes): Addressable: 00 Partially addressable: 01 02 03 04 05 06 07 Heap left redzone: fa Freed heap region: fd Stack left redzone: f1 Stack mid redzone: f2 Stack right redzone: f3 Stack after return: f5 Stack use after scope: f8 Global redzone: f9 Global init order: f6 Poisoned by user: f7 Container overflow: fc Array cookie: ac Intra object redzone: bb ASan internal: fe Left alloca redzone: ca Right alloca redzone: cb Shadow gap: cc
