Image compression. Noise in black areas of render. #86112
2 Participants
Reference: blender/blender#86112
Graphics card: GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.40
Broken: version: 2.92.0 Release Candidate, branch: master, commit date: 2021-02-19 18:02, hash:
b1142858d4
All versions.
Output 8bit images contain noise in the black background areas. Default color management settings, Filmic, exposure 0, Gamma 1.0. I've know of this issue for a number of years.
The issue only seems to apply to 8bit outputs. The attached image shows the exposed black level in Photoshop.
To reproduce:
render an empty scene with black background
save to 8 bit png or jpg file
open in image editor to inspect
Added subscriber: @OtherRealms
Added subscriber: @filedescriptor
I don't think this is a bug. When you use the 8bit JPEG compressed image format, you are limited to 256 shades of grey. That's just how it is. If you want more color information (especially for dark images), you should use a higher bit depth. You could also use an uncompressed format like PNG which will give you fewer repeating patches and more uniform noise.
Hi.
Surely values of 0,0,0 should just produce black though?
I work with large scale LED displays that only deal with an 8bit source, an rgb value of 1 in any channel is clearly visible. I've been flooring the black level in editing software and playing back as 8bit h264/h265. When using doing so in other software, a zero value will effectively mean off. However if I'm not careful a video will slip through that hasn't been floored, since its not visible and hard to detect, anything produced in Blender will result in flickering. I could output 16bit png's in all cases ( I do 50% of cases usually depending on efficiency, some diplays have extreme specs) but was thinking that there must something up on Blenders end. Here's a comparison of 8bit PNG's output and exposed from Cinema 4D and Blender.
I also saw the noise when saving out the image. Per default, Blender applies some dithering as a post-processing step.
If you turn that down to 0.0, you get the expected result.
Closing this, as it seems to be the expected behavior.
Ah yes makes sense, cheers.
