Memoryblock errors when working with materials (linux/amd) #86166
Reference: blender/blender#86166
Operating system: Linux-5.11.2-arch1-1-x86_64-with-arch 64 Bits
Graphics card: AMD Radeon RX 5700 XT (NAVI10, DRM 3.40.0, 5.11.2-arch1-1, LLVM 13.0.0) AMD 4.6 (Core Profile) Mesa 21.1.0-devel (git-f67259d83b)
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash:
02948a2cab
Worked: Same version, but it stopped working for some reason. Maybe a system update.
When working on object materials, Blender will eventually crash with Memoryblock errors. (Logs below.)
Logs
blender.crash.txt
Terminal Output.txt
system-info.txt
Final
If you want a .blend file that's close to crashing, let me know. It may be easier than recreating the scene each time.
Added subscriber: @Develon5543
Hello again. I tried this experiment again after uninstalling OpenCL on my system. I think the results are a bit different, so it might be worthwhile to check on it. Also, my system-info.txt was incomplete due to a different crash, so I'll reupload that as well. All I did this time was add an image texture and mixrgb node to all 6 sides of a cube. (Each side had a new material, so 6 materials total. Also this was done while the viewport was in material preview mode)
blender.crash.txt
Terminal Output.txt
system-info.txt
Added subscriber: @lichtwerk
Yes, please provide your example .blend file with the steps that need to be taken after opening that file to get it to crash, thx!
Hi, thanks for your response. I'm going to attach a zip file with the .blend file inside of it. It also includes image assets that were created by me in order to demonstrate the type of work I was doing while making crashes.
To reproduce crashes:
I noticed that it says "Compiling shaders..." on the bottom of the screen before Blender crashes. So it seems to be the case that shader compilation causes weird crashes here.
Crash.zip
Hello. Just a quick update. I installed amdgpu pro drivers and it made the crash stop happening. All I have to do is start blender with
progl
in front of it. (ex:progl ./blender
) This indicates an issue with the open source version of opengl.. I can mostly confirm this by noting that it was working correctly on a previous version of mesa. This could indicate a driver regression and is not fixable by blender itself. I'm not sure where this issue will go now. Perhaps it would be better off reported in mesa..Changed status from 'Needs User Info' to: 'Needs Triage'
Added subscriber: @mano-wii
I tested the file but nothing abnormal here.
Graphics card: Radeon (TM) RX 480 Graphics ATI Technologies Inc. 4.5.14760 Core Profile Context 20.45.37.01 27.20.14537.1001
It's likely that this issue only occurs on Linux while using the open source amd drivers. (AMDGPU not AMDGPU Pro.) Thank you for the windows testing though.
Added subscriber: @Jeroen-Bakker
Since this has been lying around for some time:
https://builder.blender.org/download/daily/
@Jeroen-Bakker: you've got the same card on linux afaict, are you using the open source drivers? Can reproduce?
Hello again. I downloaded the 3.0.0 alpha from the website and messed around with the shaders again for an extended period of time. I didn't experience any crashing this time. I'll provide my system information below:
OS: Archlinux (Linux 5.14.7-arch1-1 #1 SMP PREEMPT Wed, 22 Sep 2021 21:35:11 +0000 x86_64 GNU/Linux)
renderer: 'AMD Radeon RX 5700 XT (NAVI10, DRM 3.42.0, 5.14.7-arch1-1, LLVM 14.0.0)'
vendor: 'AMD'
version: '4.6 (Core Profile) Mesa 21.3.0-devel (git-db99462de6)'
Let me know if you need anything else.
Changed status from 'Needs User Info' to: 'Resolved'
Good to know :)
Many bugs are fixed between the official releases. It is quite possible that the problem has been fixed.
Closing as resolved then.
