Bake action result unexpected since 2.92 #86193
Closed
opened 2021-03-02 14:35:49 +01:00 by celpec · 17 comments
Operating system:
win10
Graphics card:
gtx1050ti
Broken: 2.92 stable, 2.93.0-c4ef90f5a0b1 master
Worked: 2.83 stable, 2.91 stable
Behavior changed in 0e85d701c6
there are 2 error from this issue.
1, the bake action handle bone's rotation as euler, then the bake result are not as expected, in frame 1 to 2 will have a large rotation.
2, change bone or armature's rotation mode from euler to quaternion then bake will cause error (this has still to be reproduced)
1, open file, bones already selected
2,bake the action use visual keying, then the action will have a incorrect rotation in 1-2 frame.
3, change mode from euler to quaternion
4, bake again and will give an error " ValueError: Matrix.to_euler(): invalid euler order 'QUATERNION' ", but this has its own report in #88359
daz_test.blend
from #88378:
** Baking animation just dont work properly in blender 2.92, it give incorrect baking starting at frame 2 ( even if you clean curves and clear parents and constraint). baking works perfectly and smoothly in blender 2.91
bakeproblem2.92.blend
**System Information** Operating system: win10 Graphics card: gtx1050ti **Blender Version** Broken: 2.92 stable, 2.93.0-c4ef90f5a0b1 master Worked: 2.83 stable, 2.91 stable Behavior changed in 0e85d701c6 **Short description of error** there are 2 error from this issue. 1, the bake action handle bone's rotation as euler, then the bake result are not as expected, in frame 1 to 2 will have a large rotation. 2, change bone or armature's rotation mode from euler to quaternion then bake will cause error (this has still to be reproduced) **Exact steps for others to reproduce the error** 1, open file, bones already selected 2,bake the action use visual keying, then the action will have a incorrect rotation in 1-2 frame. 3, change mode from euler to quaternion 4, bake again and will give an error " ValueError: Matrix.to_euler(): invalid euler order 'QUATERNION' ", but this has its own report in #88359 Based on the default startup or an attached .blend file (as simple as possible). [daz_test.blend](https://archive.blender.org/developer/F9860172/daz_test.blend) from #88378: ** Baking animation just dont work properly in blender 2.92, it give incorrect baking starting at frame 2 ( even if you clean curves and clear parents and constraint). baking works perfectly and smoothly in blender 2.91 [bakeproblem2.92.blend](https://archive.blender.org/developer/F10123408/bakeproblem2.92.blend) ![2.91.jpg](https://archive.blender.org/developer/F10123419/2.91.jpg) ![2.92.jpg](https://archive.blender.org/developer/F10123420/2.92.jpg)
Author
Added subscriber: @celpec
#88378 was marked as duplicate of this issue
celpec changed title from bake bone rotation error, and change euler to quaternion then Bake bone action error to bake action result incorrect, and change euler to quaternion then Bake action error 2021-03-02 14:38:43 +01:00
Member
Added subscriber: @lichtwerk
Member
Member
It is always preferable to not have full rigs as example files.
These of course are more complex to debug, please always try to put together a minimal example file:
  • does this also happen without visual keying?
  • does it only happen with these kinds of constraints?
I can confirm a difference in the bake though:
2.92
2.91
havent been able to reproduce this one though
Will see which commit caused this.
It is always preferable to not have full rigs as example files. These of course are more complex to debug, please always try to put together a minimal example file: - does this also happen without visual keying? - does it only happen with these kinds of constraints? - ... I can confirm a difference in the bake though: 2.92 ![image.png](https://archive.blender.org/developer/F9865431/image.png) 2.91 ![image.png](https://archive.blender.org/developer/F9865436/image.png) > 4, bake again and will give an error " ValueError: Matrix.to_euler(): invalid euler order 'QUATERNION' " havent been able to reproduce this one though Will see which commit caused this.
Member
Added subscriber: @dr.sybren
Member
So this changed in 0e85d701c6, not sure what is intended here, @dr.sybren would have to comment here.
Philipp Oeser changed title from bake action result incorrect, and change euler to quaternion then Bake action error to bake action result unexpected (and change euler to quaternion then Bake action error) 2021-03-04 12:17:35 +01:00
Member
Added subscribers: @zuraxe, @iss
Member
The quaternion error might be related, but it has also been reported separately in #88359 (Bake of animation keyframes are fail when object is quaternion define but bones is Eular define), will clean up the report description here
Philipp Oeser changed title from bake action result unexpected (and change euler to quaternion then Bake action error) to Bake action result unexpected since 2.92 2021-05-19 11:26:40 +02:00
Member
Will raise prio, since this might be a regression (looks like one)
Member
Added subscriber: @wbmoss_dev
Member
Looks like D11282: Fix #88359: Issue of object matrix order use in pose bake fixes this and the quaternion problem. Will let @dr.sybren handle the commit since we're in bcon4 and I'm not sure how all that stuff is handled.
Simple single bone repro file:
T86193_simple.blend
The object euler rotation mode doesn't match the bone's euler rotation mode. When you bake, the discontinuity occurs. If you change the object's rotation mode to match, it's fixed.
Looks like [D11282: Fix #88359: Issue of object matrix order use in pose bake](https://archive.blender.org/developer/D11282) fixes this and the quaternion problem. Will let @dr.sybren handle the commit since we're in bcon4 and I'm not sure how all that stuff is handled. Simple single bone repro file: [T86193_simple.blend](https://archive.blender.org/developer/F10128653/T86193_simple.blend) The object euler rotation mode doesn't match the bone's euler rotation mode. When you bake, the discontinuity occurs. If you change the object's rotation mode to match, it's fixed.
Added subscriber: @DreamertTooth
Thanks for finding the cause of this, @wbmoss_dev and @DreamertTooth !
This issue was referenced by a1954e3807
This issue was referenced by a1954e380730ae9d116245343d9296d587907673
Sybren A. Stüvel self-assigned this 2021-05-20 12:59:02 +02:00
https://i.kym-cdn.com/entries/icons/original/000/022/628/Screen_Shot_2017-04-05_at_2.58.07_PM.png
6 Participants
Reference: blender/blender#86193
