Geometry nodes. New/Copy button inconsistent behavior
Closed, ResolvedPublicBUG
Operating system: Windows-8.1-6.3.9600-SP0 64 Bits
Graphics card: GeForce GTX 660 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.40
Broken: version: 2.92.0 release, 2.93.0 Alpha, branch: master, commit date: 2021-03-02 07:40, hash: rBc4ef90f5a0b1
New/copy button work different, accordingly materials or particle systems for example.
It do not create copy. Also there is no direct way to create copy (duplicate) of GN-tree (and indirect have a bug now T86207)
It is inconsistent with the other mentioned, not sure it is a bug though.
Workaround for making real copies of the nodegroups:
  • Outliner > Blender File view > Node Groups > copy / paste
Scene and View Layers also use this icon, but use submenu: New, Copy Settings, etc.
Vyacheslav (hitrpr) added a comment.EditedMar 4 2021, 2:05 AM
Already tried.
Direct copy-paste have a bug.
Copying from Blender file structure creates grouped node instead tree. And ungrouping will ruin input and output
So, actually no workaround, that will give exact same result.
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.Mar 4 2021, 9:50 AM
OK, will confirm for now and check soonish
Dalai Felinto (dfelinto) changed the subtype of this task from "Report" to "Bug".
OK, since this is marked as good first issue for community contributions, will step down.
Hi, I have a working fix for this, but I have a question about how it should be implemented. I was wondering if I should implement a new operator that copies the active tree in the geometry nodes modifier, and keep the old NewGeometryNodeTreeAssign. Then assign the new operator to the relevant button, or if I should just change the functionality of NewGeometryNodeTreeAssign to copy the active tree if it exists?
