'Transformation' constraint property between two objects does not work if the "Target" object is being evaluated in "Local" space
Confirmed, NormalPublicBUG
Graphics card: Radeon (TM) RX 480 Graphics ATI Technologies Inc. 4.5.14760 Core Profile Context 20.45.37.01 27.20.14537.1000
Broken: version: 2.93.0 Alpha, branch: master, commit date: 2021-03-02 07:40, hash: rBc4ef90f5a0b1
Worked: 2.79
When adding the "Transformation" constraint property between two objects, If the "Target" object is being evaluated in the "Local" space, only the location -> rotation combination will have any results.
Also, in this case, for the rotation-> rotation combination to have any effect, it is necessary to add a parent object to the "Target".
  • Open attached file
  • With the object named "Cube.001" selected, Change the constraint "Map From" to rotation
  • Select the object named "Cube" (i is the Target)
  • Rotate the object
Nothing happens. The object must have a parent.
rB7728bfd4c45c: Constraints: remove special meaning of Local Space for parentless Objects.
rBf881162f81e5: Revert "Constraints: remove special meaning of Local Space for parentless…
It's not a bug, but is confusing. There is special handling of Local space for parentless objects. Effectively, the object's evaluated Local transform is relative to it's rotation. Thus, Local Rotation is always identity (1st video) and Local Location changes as you rotate the object (2nd video).
Weird
				Left side:			Right side:
					v2.82.7				v2.92.0
					rotation is good		rotation is bad
					parent line is good		parent line is weird
rotate the car 90°(z) ->
					loc y does not work		loc y works
All right.
Does not matter.
Next time I want to animate a car, I’m going to use the Rigacar addon.
Thank you!
