v.2.92 Does not open
Operating system: Windows 10 Home v.1909
Graphics card: NVIDIA GeForce RTX 2060 SUPER, Driver: 27.21.14.5751(Display1) and Intel UHD Graphics 630, Driver: 27.20.100.8681(Display2)
Broken: 2.92, 2021-02-25, (cannot get to splash screen)
Worked: 2.92 (It worked last week)
When I open the .exe. with any method, I see a command window for one frame and then nothing.
Could you try unplugging the Display 2 with Intel UHD Graphics 630 and then starting Blender? Also, another possible solution is to try what is mentioned in T78799.
Eric Lebow (TechPriest) closed this task as Resolved.Mar 11 2021, 4:25 PM
Eric Lebow (TechPriest) claimed this task.
Thank you @Falk David (filedescriptor) for your solution. You were correct. The Intel UHD Graphics 630 resources were not enough to support Blender. I had mistakenly used that port when I moved my system.
For others using dual monitors, Blender requirements should be met on all Graphic Cards.
Thank you again Blender Community!
Falk David (filedescriptor) changed the task status from Resolved to Archived.Mar 11 2021, 6:14 PM
Falk David (filedescriptor) removed Eric Lebow (TechPriest) as the assignee of this task.
