Random User Interface Colour Change (2.91+ Regression?) #86450
Closed
opened 2021-03-10 09:03:45 +01:00 by Alaska · 15 comments
Member
Operating system: Linux-5.10.0-3-amd64-x86_64-with-glibc2.31 64 Bits
Graphics card: RTX 3070 460.56
Graphics card: RTX 3070 461.72
Blender Version:
Broken: 2.91 release, 2.92 release, 2.93.0 Alpha 70e73974b5 2021-03-10 04:47
Worked: 2.90 and below
Caused by 7e3967ed37 (@Alaska bisected).
Note from @Alaska
Take this bisect with caution. This commit being the cause doesn't line up 100% with recent observations.
Short description of error:
Ever since Blender 2.91 I have experienced this bug where certain aspects of the UI will change colour on occasion. The areas I've seen this issue occur the most are high lighted in the image below.
This flickering seems to occur when two parts of the UI are being updated at the same time? I'm not really sure. The bug seems to occur during a change somewhere in the UI (Clicking on a box, deselecting a bunch of objects, etc), but the same actions don't always trigger this bug. There can even be long stretches of time where this bug does not occur. Hence why I have not reported it, as I've had a hard time finding a reliable way to reproduce it. However, I have found a way to reliably reproduce this issue. It can be done with a third party add-on (shown in the two videos below) or with Blender with factory defaults (as shown in the steps below)
Here's some videos showing off the issue.
This is the area where the bug occurs in the video:
GPU rendering Linux.mp4 Windows.mp4
Linux (GPU rendering) Windows (GPU rendering)
I have done three tests (Linux with GPU rendering, Linux with Software Rendering, Windows with GPU rendering) because at first I thought this might be an issue with my Linux installation or the drivers I have. So after testing Linux with GPU rendering, I tested Software Rendering, and that shows the issue, suggesting the issue isn't the GPU driver. Then I tested Windows just to make sure it's not a Linux thing, and seeing the issue show up on Windows shows it's not a Linux thing.
Exact steps for others to reproduce the error:
Unreliable method:
  1. Use Blender for an extended period of time. At some point you may bump into this issue.
Reliable method: (for me at least)
  1. In a new file, change the render engine to Cycles and select GPU compute.
  2. Disable viewport overlays in the 3D viewport.
  3. Split the 3D viewport in two and change one of them to a shader editor
  4. Entered rendered view in the 3D viewport.
  5. Adjust numerical render settings that affect Cycles rendering, causing a viewport refresh. The way you adjust these numbers is you click on it (allowing you to type in a number), then move your mouse to another input field, input a value, and press enter. (In my case, I used AO distance in the Fast GI Approximation section of the Light Paths panel of Render properties).
This change in colour in the UI will be found in the shader editor here:
Here's a video demonstrating it:
#86450 - Updated demonstation.mp4
Old method: Do not use.
Reliable method (for me - same as videos above):
  1. Install the Scatter add-on by BD3D (https://blendermarket.com/products/scatter). Sorry, it costs money. There are probably other add-ons similar to this one that would allow the easy reproduction of this bug.
  2. Open up a shader editor beside the 3D viewport.
  3. Open the "Properties Panel" in the 3D viewport with N, switch to the Scatter tab and hover your mouse over the Image area and you should see this bug.
Note: I only got the Scatter add-on yesterday (as of the time of writing). I have been experiencing this bug for a few months. The Scatter add-on is not the cause (or I don't believe). During the past few months without the Scatter add-on, I did not have any other add-ons installed (outside of the defaults like Cycles). So I do not believe add-ons are the cause.
**System Information** Operating system: Linux-5.10.0-3-amd64-x86_64-with-glibc2.31 64 Bits Graphics card: RTX 3070 460.56 Operating system: Windows-10-10.0.19041-SP0 64 Bits Graphics card: RTX 3070 461.72 **Blender Version:** Broken: 2.91 release, 2.92 release, 2.93.0 Alpha `70e73974b5` 2021-03-10 04:47 Worked: 2.90 and below Caused by 7e3967ed37 (@Alaska bisected). > Note from @Alaska > Take this bisect with caution. This commit being the cause doesn't line up 100% with recent observations. **Short description of error:** Ever since Blender 2.91 I have experienced this bug where certain aspects of the UI will change colour on occasion. The areas I've seen this issue occur the most are high lighted in the image below. ![Affected Regions.png](https://archive.blender.org/developer/F9882491/Affected_Regions.png) This flickering seems to occur when two parts of the UI are being updated at the same time? I'm not really sure. The bug seems to occur during a change somewhere in the UI (Clicking on a box, deselecting a bunch of objects, etc), but the same actions don't always trigger this bug. There can even be long stretches of time where this bug does not occur. Hence why I have not reported it, as I've had a hard time finding a reliable way to reproduce it. However, I have found a way to reliably reproduce this issue. It can be done with a third party add-on (shown in the two videos below) or with Blender with factory defaults (as shown in the steps below) Here's some videos showing off the issue. This is the area where the bug occurs in the video: ![Affected part of video.png](https://archive.blender.org/developer/F9882527/Affected_part_of_video.png) |[GPU rendering Linux.mp4](https://archive.blender.org/developer/F9882499/GPU_rendering_Linux.mp4)|[Windows.mp4](https://archive.blender.org/developer/F9882505/Windows.mp4)| | -- | -- | |Linux (GPU rendering)|Windows (GPU rendering)| I have done three tests (Linux with GPU rendering, Linux with Software Rendering, Windows with GPU rendering) because at first I thought this might be an issue with my Linux installation or the drivers I have. So after testing Linux with GPU rendering, I tested Software Rendering, and that shows the issue, suggesting the issue isn't the GPU driver. Then I tested Windows just to make sure it's not a Linux thing, and seeing the issue show up on Windows shows it's not a Linux thing. **Exact steps for others to reproduce the error:** **Unreliable method:** 1. Use Blender for an extended period of time. At some point you may bump into this issue. Reliable method: (for me at least) 1. In a new file, change the render engine to Cycles and select GPU compute. 2. Disable viewport overlays in the 3D viewport. 3. Split the 3D viewport in two and change one of them to a shader editor 4. Entered rendered view in the 3D viewport. 5. Adjust numerical render settings that affect Cycles rendering, causing a viewport refresh. The way you adjust these numbers is you click on it (allowing you to type in a number), then move your mouse to another input field, input a value, and press enter. (In my case, I used AO distance in the `Fast GI Approximation` section of the `Light Paths` panel of `Render properties`). This change in colour in the UI will be found in the shader editor here: ![#86450 - Location of UI flicker.png](https://archive.blender.org/developer/F9930022/T86450_-_Location_of_UI_flicker.png) Here's a video demonstrating it: [#86450 - Updated demonstation.mp4](https://archive.blender.org/developer/F9930020/T86450_-_Updated_demonstation.mp4) --- **Old method: Do not use.** > **Reliable method (for me - same as videos above):** > 1. Install the `Scatter` add-on by BD3D (https://blendermarket.com/products/scatter). Sorry, it costs money. There are probably other add-ons similar to this one that would allow the easy reproduction of this bug. > 2. Open up a shader editor beside the 3D viewport. > 3. Open the "Properties Panel" in the 3D viewport with `N`, switch to the `Scatter` tab and hover your mouse over the `Image area` and you should see this bug. > > Note: I only got the `Scatter` add-on **yesterday (as of the time of writing)**. I have been experiencing this bug for a few months. The `Scatter` add-on is not the cause (or I don't believe). During the past few months without the `Scatter` add-on, I did not have any other add-ons installed (outside of the defaults like Cycles). So I do not believe add-ons are the cause.
Author
Member
Added subscriber: @Alaska
Member
Added subscriber: @filedescriptor
Member
It would be good to have a way of reproducing it without relying on an addon (that is not included with blender). Will mark this as a UI papercut for now.
Author
Member
I'm sorry I don't have a reliable way that doesn't use an add-on. The bug just seems to occur at random when not using this add-on and I can't figure out why.
As a side note, I decided to bisect the issue and found this commit to be the culprit (from my testing) 7e3967ed37
I have confirmed that this commit is the culprit by testing this commit and the previous commit multiple times and transplanting the affected file from a previous revision of Blender into master (2.93).
> In #86450#1127321, @filedescriptor wrote: > It would be good to have a way of reproducing it without relying on an addon (that is not included with blender). Will mark this as a UI papercut for now. I'm sorry I don't have a reliable way that doesn't use an add-on. The bug just seems to occur at random when not using this add-on and I can't figure out why. As a side note, I decided to bisect the issue and found this commit to be the culprit (from my testing) 7e3967ed37 I have confirmed that this commit is the culprit by testing this commit and the previous commit multiple times and transplanting the affected file from a previous revision of Blender into master (2.93).
Author
Member
This factor of the code being the culprit is also supported by the fact that disabling Gizmos in the 3D viewport resolves this issue, even when using the add-on.
This factor of the code being the culprit is also supported by the fact that disabling `Gizmos` in the 3D viewport resolves this issue, even when using the add-on.
Author
Member
@filedescriptor I believe I have found another way to reproduce the bug. I'm not sure why this way works, but it works for me. Some steps are not necessary, but seem to make it more re-producable.
  3. Split the 3D viewport in two so you have a shader editior and 3D viewport open side by side.
@filedescriptor I believe I have found another way to reproduce the bug. I'm not sure why this way works, but it works for me. Some steps are not necessary, but seem to make it more re-producable. 1. In a new file, change the render engine to Cycles and select GPU compute. 2. Disable viewport overlays in the 3D viewport. 3. Split the 3D viewport in two so you have a shader editior and 3D viewport open side by side. 4. Entered rendered view in the 3D viewport. 5. Adjust numerical render settings that affect Cycles rendering, causing a viewport refresh. The way you adjust these numbers is you click on it (allowing you to type in a number), then move your mouse to another input field, input a value, and press enter. (In my case, I used AO distance in the `Fast GI Approximation` section of the `Light Paths` panel of `Render properties`). This change in colour in the UI will be found in the shader editor here: ![#86450 - Location of UI flicker.png](https://archive.blender.org/developer/F9930022/T86450_-_Location_of_UI_flicker.png) Here's a video demonstrating it: [#86450 - Updated demonstation.mp4](https://archive.blender.org/developer/F9930020/T86450_-_Updated_demonstation.mp4)
Member
Member
I was able to reproduce this on the latest 2.93.0 Alpha, branch: master, commit date: 2021-04-14 12:25, hash: b9207fb43d.
I was able to reproduce this on the latest 2.93.0 Alpha, branch: master, commit date: 2021-04-14 12:25, hash: `b9207fb43d`.
Member
Member
There seem to be multiple ways to trigger this, not just the add-on. It also appeared while testing D8084 and in the asset-browser-poselib branch when selecting poses from the asset view (sidebar), see #87623.
There seem to be multiple ways to trigger this, not just the add-on. It also appeared while testing [D8084](https://archive.blender.org/developer/D8084) and in the `asset-browser-poselib` branch when selecting poses from the asset view (sidebar), see #87623.
Author
Member
I know I said the bug was initially caused by 7e3967ed37 but some of the stuff I've seen recently doesn't line up with that observation. Maybe I bisected incorrectly or this bug is now occurring in more places due to other commits.
I will look into bisecting again and see what else I can find.
I know I said the bug was initially caused by 7e3967ed37 but some of the stuff I've seen recently doesn't line up with that observation. Maybe I bisected incorrectly or this bug is now occurring in more places due to other commits. I will look into bisecting again and see what else I can find.
Added subscriber: @ideasman42
This was caused by 405a5d3bd7.
For reference another way to reproduce the bug as I couldn't use the method from this report.
With this blend file split_icon_dark.blend:
  • Hover your mouse cursor over the toolbar (ensure the tool-bar's scroll-bar is visible).
  • Press Ctrl-Space twice.
  • Notice the top left area switcher draws much darker.
Example video:
T86450_example.mp4
This was caused by 405a5d3bd7. For reference another way to reproduce the bug as I couldn't use the method from this report. With this blend file [split_icon_dark.blend](https://archive.blender.org/developer/F10046570/split_icon_dark.blend): - Hover your mouse cursor over the toolbar (ensure the tool-bar's scroll-bar is visible). - Press Ctrl-Space twice. - Notice the top left area switcher draws much darker. Example video: [T86450_example.mp4](https://archive.blender.org/developer/F10046573/T86450_example.mp4)
This issue was referenced by b7f3ebe014
This issue was referenced by b7f3ebe014a250c417f7d0810aa102067979477d
Campbell Barton self-assigned this 2021-05-01 16:13:14 +02:00
5 Participants
Reference: blender/blender#86450
