Lock to Object Doesn't work
Operating system: Win 10 Home
Graphics card: RTX 2060
Broken: 2.92.0 (no other info on splash screen)
Worked: don't know??
Short description of error and steps
  1. Create new blend file
  2. Add a plan
  3. Go to N-Panel / View tab
  4. Under "View Lock" section
  5. Select (or enter the object from dropdown/or enter text or use eye dropper
  6. Rotate the viewport.
The object still rotates in the viewport on the established axis.... so, it IS NOT LOCKED to viewport.
Thanks
The "Lock to object" option will make the view follow the object. You can move the view freely around, but when you move the object itself, the view will follow (lock to it). Closing. This is not a bug.
