PYTHON: bpy_extras.mesh_utils.mesh_linked_uv_islands Creates Exception in EditMode
Broken: 2.92 official release
I tested bpy_extras.mesh_utils.mesh_linked_uv_islands function. It works nice in ObjectMode but it creates an error in EditMode. Is it a bug?
  • Open my blend file
  • Go to EditMode
  • Run a script. There will be Exception
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.Mar 11 2021, 10:34 AM
Philipp Oeser (lichtwerk) added projects: Python API, Restricted Project.
Can confirm
Sorry, forgot that this is a general case, the way the script accesses mesh data is not suited for editmode
https://docs.blender.org/api/master/bpy.types.Mesh.html
The mesh data is accessed in object mode and intended for compact storage, for more flexible mesh editing from python see bmesh
So, uv_layers is not available in editmode.
We could go through bmesh instead (then to be found in uv_layer = bm.loops.layers.uv.active) or switch to objectmode in this case (think this is what most scripts do?)
In any case, we should not throw an error.
I have put up a patch preventing the error [and going through bmesh if in editmode].
I am unsure though if bmesh is allowed inside mesh_utils, so outcome might just be that mesh_linked_uv_islands will return an empty list instead.
But of course you will want to have this working in editmode, so for now you can also just do
is_editmode = (ob.mode == 'EDIT')
if is_editmode:
  bpy.ops.object.mode_set(mode='OBJECT', toggle=False)
do the call
if is_editmode:
  bpy.ops.object.mode_set(mode='EDIT', toggle=False)
Thank you! I'll write a small comment there.
Will have to concentrate on triaging for a while (and step down).
Campbell Barton (campbellbarton) moved this task from Restricted Project Column to Restricted Project Column on the Restricted Project board.May 3 2022, 6:14 AM
Campbell Barton (campbellbarton) added a project: Restricted Project.
Use bpy_extras.bmesh_utils.bmesh_linked_uv_islands instead.
