white artifacts in EEVEE #86578
Closed
opened 2021-03-15 11:44:17 +01:00 by guang liang chen · 88 comments
Graphics card: GeForce GTX 670/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 451.67
Broken: version: 2.92, 2.93.0 Alpha, branch: master, commit date: 2021-03-14 22:11, hash: 070010e203
Worked: 2.91
White NaN pixels appearing when using EEVEE. It's less apparent in the viewport than in renders as the number of artifacts depends on the number of samples.
spekles in eevee.blend
Open the attached file, switch to viewport rendering, hit F12.
**System Information** Operating system: Windows-10-10.0.18362-SP0 64 Bits Graphics card: GeForce GTX 670/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 451.67 **Blender Version** Broken: version: 2.92, 2.93.0 Alpha, branch: master, commit date: 2021-03-14 22:11, hash: `070010e203` Worked: 2.91 **Short description of error** White NaN pixels appearing when using EEVEE. It's less apparent in the viewport than in renders as the number of artifacts depends on the number of samples. ![error.jpg](https://archive.blender.org/developer/F9892502/error.jpg) [spekles in eevee.blend](https://archive.blender.org/developer/F9892506/spekles_in__eevee.blend) **Exact steps for others to reproduce the error** Open the attached file, switch to viewport rendering, hit F12.
Added subscriber: @imdjs
#88643 was marked as duplicate of this issue
#87412 was marked as duplicate of this issue
#87391 was marked as duplicate of this issue
#87248 was marked as duplicate of this issue
#86752 was marked as duplicate of this issue
#86795 was marked as duplicate of this issue
#86681 was marked as duplicate of this issue
#87233 was marked as duplicate of this issue
#87202 was marked as duplicate of this issue
#87072 was marked as duplicate of this issue
#87059 was marked as duplicate of this issue
#87024 was marked as duplicate of this issue
#86855 was marked as duplicate of this issue
Philipp Oeser changed title from got white spekles in EEVEE(blender2.92 2.93) to white artifacts in EEVEE 2021-03-15 15:14:06 +01:00
Member
Member
Added subscribers: @fclem, @lichtwerk
Member
This works for me in 2.92 though, only seeing those in 2.93
Operating system: Linux-5.10.19-200.fc33.x86_64-x86_64-with-glibc2.32 64 Bits
Graphics card: GeForce GTX 970M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 455.45.01
version: 2.93.0 Alpha, branch: master, commit date: 2021-03-15 12:31, hash: `rBab6e67767e73`
In contrast to similar reports we had recently, these dont seem related to screen space reflections.
CC @fclem
This works for me in 2.92 though, only seeing those in 2.93 ``` **System Information** Operating system: Linux-5.10.19-200.fc33.x86_64-x86_64-with-glibc2.32 64 Bits Graphics card: GeForce GTX 970M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 455.45.01 version: 2.93.0 Alpha, branch: master, commit date: 2021-03-15 12:31, hash: `rBab6e67767e73` ``` In contrast to similar reports we had recently, these dont seem related to screen space reflections. CC @fclem
I cannot repro here (AMD + Linux) Will test on another config.
Added subscriber: @leonardos
cant reproduce win 10 + amd 2.93
Added subscriber: @MLSpence
Member
Added subscriber: @EAW
Member
I can reproduce as I have a NVIDIA GPU.
Some observations:
  • The nan pixels are in the diffuse direct pass.
  • They go away when I turn off the Subdivision surface modifier, which makes me wonder if that is part of the issue. I'll see if the other reports all have subdivision surface modifiers as well.
Tested using:
version: 2.93.0 Alpha, branch: master, commit date: 2021-03-18 17:07, hash: b1150fa1f5, type: Release
OS: Windows-10-10.0.19041.630-SP0 64 Bits
GPU: GeForce GTX 470/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 391.35
CPU: i7-950 @3.07 GHz SSE2 SSE3 SSE41
RAM: 8.00 GB
I can reproduce as I have a NVIDIA GPU. Some observations: - The nan pixels are in the diffuse direct pass. - They go away when I turn off the Subdivision surface modifier, which makes me wonder if that is part of the issue. I'll see if the other reports all have subdivision surface modifiers as well. ``` ``` --- Tested using: version: 2.93.0 Alpha, branch: master, commit date: 2021-03-18 17:07, hash: b1150fa1f5a5, type: Release OS: Windows-10-10.0.19041.630-SP0 64 Bits GPU: GeForce GTX 470/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 391.35 CPU: i7-950 @3.07 GHz SSE2 SSE3 SSE41 RAM: 8.00 GB
Added subscriber: @joaulo
Added subscriber: @BalazsGyutai
Member
Added subscribers: @Gandarufu, @PratikPB2123
Added subscriber: @TheJeran
i was able to reproduce this in the viewport, image.png so i believe this isn't just a render image only thing. It also happened more often when I turned on "High Quality Normals" in the performance settings.
i was able to reproduce this in the viewport, ![image.png](https://archive.blender.org/developer/F9910781/image.png) so i believe this isn't just a render image only thing. It also happened more often when I turned on "High Quality Normals" in the performance settings.
Added subscriber: @sgds
Added subscriber: @carlos13eab
Added subscriber: @pietrodichito
Member
Added subscriber: @borschberry
I only had this problem in 2.93 but now it just happend in 2.91 as well (Evee, Viewport&Render):
I updated my nvidia drivers but it did not help.
Update: Turning down specular completely in the principled shader solved it.
I only had this problem in 2.93 but now it just happend in 2.91 as well (Evee, Viewport&Render): ![blender_WhiteDots_01.png](https://archive.blender.org/developer/F9914797/blender_WhiteDots_01.png) I updated my nvidia drivers but it did not help. Update: Turning down specular completely in the principled shader solved it.
Member
Added subscriber: @TheCrowdedOne
Added subscriber: @geocentric_wage
I can confirm that it happens in Eevee-renders in 2.91 as well.
Member
Added subscriber: @AmirShehata
I've tried this, doesnt seem to be anything to do with screen space refractions, volumes or anything like that, they appear as samples progress. This doesnt happen to me in Blender 2.92 but happens in 2.93. I really hope this will be an EZ fix, because 2.93 got some amazing eevee updates i need to get my hands on.
Added subscriber: @cocoreysa
Here's my example of this, It stops/moves when I disconnect the normal from the materials. Using Blender 2.93 that was released on the 31st of March (I have an Nvidia 1080)
Here's an example of the it effecting the Bloom.
Here's my example of this, It stops/moves when I disconnect the normal from the materials. Using Blender 2.93 that was released on the 31st of March (I have an Nvidia 1080) ![Overlay2.png](https://archive.blender.org/developer/F9916989/Overlay2.png) Here's an example of the it effecting the Bloom. ![Overlay1.png](https://archive.blender.org/developer/F9916991/Overlay1.png)
I've recreated the effect in the file below, just hit render and you should be able to see. (in 2.93 released on April 1st)
FresnelBug293.blend
I've recreated the effect in the file below, just hit render and you should be able to see. (in 2.93 released on April 1st) [FresnelBug293.blend](https://archive.blender.org/developer/F9917293/FresnelBug293.blend)
Member
In #86578#1136836, @MLSpence wrote:
i was able to reproduce this in the viewport, so i believe this isn't just a render image only thing.
I hadn’t noticed that the report said it only occurred in the render. As I can confirm that it occurs in the viewport as well, I’ll update the report.
> In #86578#1136836, @MLSpence wrote: > i was able to reproduce this in the viewport, so i believe this isn't just a render image only thing. I hadn’t noticed that the report said it only occurred in the render. As I can confirm that it occurs in the viewport as well, I’ll update the report.
Contributor
Added subscriber: @AndresStephens
Contributor
Can confirm. Should be a high priority bug.
Relevant tasks:
https:*developer.blender.org/T86795
https:*developer.blender.org/T86752
Can confirm. Should be a high priority bug. Relevant tasks: [https:*developer.blender.org/T86795 ](https:*developer.blender.org/T86795) [https:*developer.blender.org/T86752 ](https:*developer.blender.org/T86752)
Contributor
You can see the issue happening in the Diffuse Light AOV of the Eevee render.
![bforartists_nr8bDBCsut.png](https://archive.blender.org/developer/F9917325/bforartists_nr8bDBCsut.png) You can see the issue happening in the Diffuse Light AOV of the Eevee render.
Added subscriber: @viadvena
Operating system: Linux-4.15.0-140-generic-x86_64-with-glibc2.27 64 Bits
Graphics card: GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 450.102.04
Broken: version: 2.93.0 Alpha, branch: master, commit date: 2021-04-01 21:49, hash: d91fec1a85
Same problem.
With SSR
Without SSR
**System Information** Operating system: Linux-4.15.0-140-generic-x86_64-with-glibc2.27 64 Bits Graphics card: GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 450.102.04 **Blender Version** Broken: version: 2.93.0 Alpha, branch: master, commit date: 2021-04-01 21:49, hash: `d91fec1a85` Worked: (newest version of Blender that worked as expected) Same problem. **With SSR** ![Screenshot_20210402_145653.png](https://archive.blender.org/developer/F9917839/Screenshot_20210402_145653.png) **Without SSR** ![Screenshot_20210402_145658.png](https://archive.blender.org/developer/F9917841/Screenshot_20210402_145658.png)
Member
Added subscriber: @Shady.Hamza
Added subscriber: @jaggz
As I posted in https://developer.blender.org/T87233
It's produced in a scene with geometry and no light source at all.
Can anyone confirm that it does not occur with other shader's than Principled?
  1. It happens with different object types (I've done it with mesh and beveled curves).
  2. It is not reliant upon subdiv modifier (although that can change the geometry, increasing or reducing its occurence).
  3. It is not affected by specular value in my tests.
  4. I think I've noticed it only at the edges of objects (where the normal is perpendicular to the camera/view?)
  5. It happens with Principled Shader, and no values within the shader will stop it or affect it.
  6. I haven't found another shader (but haven't tested much) that can cause it. If I swap principled with diffuse, it doesn't seem to happen at all.
Since its value is so extreme, I'm taking an initial wild guess that some shader calculation, with just the right circumstances, possibly a surface tangent to the view, is sending a value off to infinity (or denominator to near 0, or 0+some fudge factor).
It's just the point/points at that precise location where that value blows up (or goes to 0), and later goes through SSR, bloom, or whatever, to make it spectacular. Here it is, caused by a Curve object with Principled (later processing of SSR, Emission=10.0 makes it more visible):
As I posted in https://developer.blender.org/T87233 It's produced in a scene with geometry and no light source at all. Can anyone confirm that it does not occur with other shader's than Principled? 1. It happens with different object types (I've done it with mesh and beveled curves). 2. It is not reliant upon subdiv modifier (although that can change the geometry, increasing or reducing its occurence). 3. It is not affected by specular value in my tests. 3. I *think* I've noticed it only at the edges of objects (where the normal is perpendicular to the camera/view?) 4. It happens with Principled Shader, and no values within the shader will stop it or affect it. 5. I haven't found another shader (but haven't tested much) that can cause it. If I swap principled with diffuse, it doesn't seem to happen at all. Since its value is so extreme, I'm taking an initial wild guess that some shader calculation, with just the right circumstances, possibly a surface tangent to the view, is sending a value off to infinity (or denominator to near 0, or 0+some fudge factor). It's just the point/points at that precise location where that value blows up (or goes to 0), and later goes through SSR, bloom, or whatever, to make it spectacular. Here it is, caused by a Curve object with Principled (later processing of SSR, Emission=10.0 makes it more visible): ![Screenshot_20210406_114713.png](https://archive.blender.org/developer/F9922110/Screenshot_20210406_114713.png)
Member
Added subscriber: @zanqdo
Member
I've created a possibly related report #87248
For me the problem seems to be present only when the Jitter Camera option is used
I've created a possibly related report #87248 For me the problem seems to be present only when the *Jitter Camera* option is used
Member
Added subscriber: @filedescriptor
Added subscriber: @Robert_B
I have the same problem. The NaN pixels are also available without SSR and jitter camera. I tested version 2.93 alpha in Windows and Linux. Car_Firefly.jpg
I have the same problem. The NaN pixels are also available without SSR and jitter camera. I tested version 2.93 alpha in Windows and Linux. ![Car_Firefly.jpg](https://archive.blender.org/developer/F9923158/Car_Firefly.jpg)
@jaggz This bug feeling good with other shaders:
And how I remember this bug was appear in previous versions of blender and it was successfully resolved. I don't know what the essence was. There was thoughts that it's all due errors in Nvidia drivers...
@jaggz This bug feeling good with other shaders: ![Screenshot_20210408_000007.png](https://archive.blender.org/developer/F9923276/Screenshot_20210408_000007.png) ![Screenshot_20210408_000020.png](https://archive.blender.org/developer/F9923277/Screenshot_20210408_000020.png) ![Screenshot_20210408_000025.png](https://archive.blender.org/developer/F9923278/Screenshot_20210408_000025.png) And how I remember this bug was appear in previous versions of blender and it was successfully resolved. I don't know what the essence was. There was thoughts that it's all due errors in Nvidia drivers...
Added subscriber: @MichaelHermann
Added subscriber: @dfelinto
@fclem I can reproduce it here:
Operating system: Linux-5.8.0-45-generic-x86_64-with-glibc2.31 64 Bits
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 450.102.04
Latest master. In 2.91 it was indeed working still.
@fclem I can reproduce it here: Operating system: Linux-5.8.0-45-generic-x86_64-with-glibc2.31 64 Bits Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 450.102.04 Latest master. In 2.91 it was indeed working still.
This issue was referenced by 5c4d24e1fd
This issue was referenced by 5c4d24e1fd752a8a89d44d05e8e3f9b31f2d7db0
Clément Foucault self-assigned this 2021-04-08 17:10:20 +02:00
Added subscribers: @EvaVomhoff, @TimBL, @razed, @SteffenD, @VincentMaurer
Added subscribers: @AlSande, @Firepal
Added subscribers: @MadRabidz, @PaganHead, @TravisOBrien
Member
This is not over yet!
DOF BUG.blend
Ok hints on this one:
The problem seems to be related to the custom split normals AND the sharp edges (this mesh has been imported from an alembic file)
Turning off Ambient Occlusion gets rid of the problem
This is not over yet! ![image.png](https://archive.blender.org/developer/F9926333/image.png) [DOF BUG.blend](https://archive.blender.org/developer/F9926336/DOF_BUG.blend) Ok hints on this one: The problem seems to be related to the custom split normals AND the sharp edges (this mesh has been imported from an alembic file) Turning off Ambient Occlusion gets rid of the problem
Member
Changed status from 'Resolved' to: 'Confirmed'
@zanqdo I just tried your file. There is a problem in ultra low value for AO "Distance" in compare with the scale of the scene. So you can just increase a little bit value and it will be working perfect. So, artifacts going to appears when AO "Distance" is very low and "Auto Smooth" is enabled.
Screencast-2021-04-09_10.59.47.mp4
Screencast-2021-04-09_11.06.10.mp4
@zanqdo I just tried your file. There is a problem in ultra low value for AO "Distance" in compare with the scale of the scene. So you can just increase a little bit value and it will be working perfect. So, artifacts going to appears when AO "Distance" is very low and "Auto Smooth" is enabled. [Screencast-2021-04-09_10.59.47.mp4](https://archive.blender.org/developer/F9926601/Screencast-2021-04-09_10.59.47.mp4) [Screencast-2021-04-09_11.06.10.mp4](https://archive.blender.org/developer/F9926602/Screencast-2021-04-09_11.06.10.mp4)
@zanqdo if the file of this report is now working (as it is), any new issue should be then reported as a new bug. Closing it for now. Feel free to add me as a subscriber to the new report. Remember to also mention that the issue doesn't happen in 2.92 again.
@fclem FYI I can reproduce the issue with the latest file Daniel shared.
@zanqdo if the file of this report is now working (as it is), any new issue should be then reported as a new bug. Closing it for now. Feel free to add me as a subscriber to the new report. Remember to also mention that the issue doesn't happen in 2.92 again. @fclem FYI I can reproduce the issue with the latest file Daniel shared.
Member
@dfelinto Sure thing, will create new report now
Member
Added subscriber: @zrp
This comment was removed by @zrp
*This comment was removed by @zrp*
Member
Removed subscriber: @filedescriptor
Member
Added subscriber: @bowserlm
I see this is marked as Resolved. I'm still getting these artifacts on the latest 2.93 Beta build from 4/15. What was the solve?
Member
Can you try disabling AO? If that fixes it then it's another bug which has been also reported
> In #86578#1147738, @bowserlm wrote: > I see this is marked as Resolved. I'm still getting these artifacts on the latest 2.93 Beta build from 4/15. What was the solve? Can you try disabling AO? If that fixes it then it's another bug which has been also reported
Yeah I tried disabling AO. Made no difference in my case. Nan pixels still there.
Added subscriber: @YAFU
@bowserlm, Can you reproduce the problem with the shared .blend file on the first post of the report? If not, what is the .blend file where the problem can be reproduced?
Here's the Blend file https://www.dropbox.com/s/7kerknfetbbrwfr/Creature.blend?dl=0 And here is what I'm seeing https://jmp.sh/Pda1S6k
@bowserlm, Please, you open a new report. You do it from Blender so it collects information from your system and hardware. From Blender "Help" menu, "Report a bug". Share that .blend file and video with developers.
Member
Member
Added subscriber: @brecht
Member
We have it back (since ba4228bcf7)
@brecht, @fclem: was there really no middleground between this and #88368?
We have it back (since ba4228bcf7) @brecht, @fclem: was there really no middleground between this and #88368?
Member
Added subscriber: @SachaGoedegebure
This issue was referenced by c369382977
This issue was referenced by c36938297753ac45316f0b10b7d3e2f5307a6aff
Thomas Dinges added this to the 2.93 LTS milestone 2023-02-07 18:46:16 +01:00
29 Participants
Reference: blender/blender#86578
