Fix Remesh in Sculpt Mode
Windows 10
2.8x-2.9x
Main problem when i sculpt that when i use shortcuts for remesh Shift+R/Ctrl+R sometimes i get voxel size 0.0001 or lower and it crashes my blender. I mean i wish i could put a max cap on the smallest voxel size so it wont crash even if missclick on the proffered voxel size.
It's a UI problem or what? Hope its not just me.
This report does not contain the requested information, which is required for us to investigate the issue. Please read this guide, it may help you write a bug report that allows us to fix your problem.
In case you believe that you've found a bug, please create a new bug report through Help > Report a Bug in Blender. We expect all bug reports to follow the submission template. Please provide system information (operating system, GPU, driver version), affected Blender version, previous Blender version that worked properly, a short and precise description of the issue, step by step instructions to reproduce it and, if relevant, a minimal .blend file that showcases the problem.
