Pie menu: PIE_OT_SetObjectModePie() in space_view3d_pie_menus is not adding an undo step when executed #86707
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#86707
Operating system: Win10 64
Graphics card: GTX1070
Broken:
2.93 Alpha d7fb38ddd4af (and likely before)
PIE_OT_SetObjectModePie() in space_view3d_pie_menus is not adding an undo step when executed. For example used by gpencil mode switching and armature pose/object mode switching. This leads to the annoying behavior where if you switch a mode using a pie menu, do something (for example sculpt) and undo directly after, the mode switch is undone as well.
I fixed it temporarily by adding 'UNDO' to the operator bl_options but there's probably a nicer way since this makes the undo history say "Set the object interactive mode" instead of showing the actual mode.
From startup blend: (assuming pie menus are enabled)
Expected:
Added subscriber: @cyaoeu
Added subscriber: @OmarEmaraDev
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
An undo step is only necessary if the ID data are changed, so this is not considered a bug, but I will let the developer make a more informed decision.
