Operating system: *
Graphics card: *
Broken: Blender 2.93 (after https://developer.blender.org/rBc44c611c6d8c6ae071b48efb5fc07168f18cd17e)
This is somewhat rare, but IMO perfectly valid Python use case of dynamically creating a new class and then wanting to register it. That is, we want to dynamically subtype a PropertyGroup class, add some properties to it, and then register the class
One example of "why", is for example MaterialX gives us a whole bunch of shader node types specified in xml files that we would like to create custom node types from, so we write a small script to parse the XML and create node classes on the fly.
import bpy data = { 'bl_label': "MyNewType", 'bl_idname': "test.MyNewType", '__annotations__': { "MyIntVal": (bpy.props.IntProperty, {'name': "MyIntVal", 'default': 42}) } } my_new_type = type("MyNewType", (bpy.types.PropertyGroup,), data) bpy.utils.register_class(my_new_type) bpy.types.Object.my_prop_grp = bpy.props.PointerProperty(type=my_new_type) print(bpy.data.objects[0].my_prop_grp.MyIntVal)
also attached a blend file with the above script. In 2.93 does not seem like it registers the int property.
. I'm tagging @Campbell Barton (campbellbarton) in this because it seems related to the DeferredProperty when we inspect deeper. If there is another way to achieve creating the properties for these dynamic types let me know.
