Volume Emission Material Overflow(?) on Hard Edges (Cycles) #86742
Reference: blender/blender#86742
Graphics card: GeForce RTX 3090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.92
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash:
02948a2cab
Worked: Unknown, is present in versions back to 2.8
When creating a volume emission material, applying it to an object, and placing said material on an object, fireflies will form on hard mesh edges when there is geometry behind it.
It is difficult to reproduce accurately, and will sometimes not occur. It also seems to be vaguely dependent on distance from origin point of the scene, but I have seen this at close to 0,0,0 and distance is simply more likely to show it, indicating floating point math errors? (Also more visible when scene is scaled to micro levels).
1: Create a primitive or use the default cube, and in its material, create a single Emission node and apply it to the Volume node of the default output.
2: Create a second primitive larger than the first, place it such that it is behind the emission object in your perspective.
If the bug is triggered you will see white fireflies at the hard edges of the silhouette of the emission object as seen in render view and final render, as seen here:
Bug is also visible in cases of semi-transparency, such as this example with a gradient + noise applied:
I have included the .blend file these images are from, with a stripped out version of the scene. I have left the more advanced world and emission materials in the hope it helps find the issue.
It can be mitigated by applying a standard Laplacian Smooth modifier to the primitive (and changing no values, probably fixing the math??), however for more advanced objects this isn't feasible.
It seems related to the density of the volume, for if you turn up the density the fireflies lessen or disappear, even by applying a multiplier to the gradient example shown above.
Strength of the fireflies is directly proportional to the strength of the emission of the volume, as seen here:
What it is not:
New as of 2021/05/30
I surmise there is some kind of overflow happening producing these very specific edge fireflies on object. Whatever it is, it's a disruption to the use of these materials.
See blend file: volume_assistance.blend
Excuse the number of edits, I'm trying to do this right.
Added subscriber: @Tetrino
#89814 was marked as duplicate of this issue
Added subscriber: @lichtwerk
Can confirm, also present in 2.93
074b0b6da0
.I'm adding an extra to the topic, I tried to find a workaround with holdout layers and it turns out that even when an object behind the volume is is not being rendered, the mere existence of it is enough to trigger this issue. Oddly, it does not occur in any reflections, which work as intended.
I know this isn't likely to be solved until Cycles X gets to volumes, but it's a real ballache in the mean time!
Added subscriber: @brecht
Now Cycles X has basic support for this, I loaded the file into that experimental build (committed 09 Jul) and saw the same behaviour.
Tagging @brecht in this only because he's been working in this area of code very recently with Cycles X, so would have a better potential idea on where the issue may lie for a fix during the cycles rewrite. Sorry Brecht I know you're busy as hell, feel free to ignore.
Added subscriber: @SimonThommes
