Texture Painting not updating cycles shader in viewport #86787
9 Participants
Reference: blender/blender#86787
Operating system: Linux-5.8.0-44-generic-x86_64-with-debian-bullseye-sid 64 Bits
Graphics card: Mesa Intel(R) Xe Graphics (TGL GT2) Intel 4.6 (Core Profile) Mesa 20.2.6
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash:
02948a2cab
Level 1. When texture painting in the 3D viewport, the image is updated, but the visible shader on the object doesn't update in cycles until switching to viewport shading and back to cycles.
It still works when switching to Eevee shading. When reloading the image in the shader image texture node, it updates in cycles, but the problem persists when the image is updated (painted on) again.
Level 2. The above bug becomes worse as follows:
In cycles the image stops updating even when switching to viewport shading and back to cycles.
(A)-When reloading the image in the shader image texture node, it updates in cycles, but any new paint on the texture in the viewport or image editor -> paint mode won't update until step A is repeated.
I do not know exactly what triggers this 2nd level bug, but it doesn't take long to show up.
I was able to repeat it just by painting and switching between Eevee and cycles using my test .blend file (attached)
Assign a material with an image node to an unwrapped object
Switch to viewport texture painting and start painting on the image in cycles shading.
The image updates in viewport shading, but not the visible shader on the object in cycles.
Switch to Eevee shading - now eveything works as expected.
I do not know what triggers the level 2 bug.
Cycles not painting on Cube.blend
Added subscriber: @DeXoN
#103655 was marked as duplicate of this issue
#101032 was marked as duplicate of this issue
Added subscriber: @lichtwerk
This is a known limitation.
Cycles works best with files saved to disk.
There were reports about this before, these were normally closed, but I think it does not do harm to have one report for this open as reference.
Note this will probably be tackled with #54656 (Cycles/Eevee texture nodes for modifiers, painting and more)
Added subscriber: @Jason-Lai
Added subscriber: @ziflin
I can confirm this still occurs in v3.0. Cycles stops rendering changes made to textures (Texture Paint in 2d or 3d) for externally saved textures. This happens fairly often when painting in Material Preview mode using Evee and switching to Rendered mode using Cycles. I'm unable to get Cycles viewport renderers to update/refresh the texture by any means that I can think of other than restarting Blender.
It clearly seems like a bug as it works fine until it stops. It seriously needs to be fixed as it makes trying to preview texturing painting in Cycles useless when it occurs.
Added subscribers: @Piergiorgio_PG, @OmarEmaraDev
Added subscriber: @JorgeBurrezo
In 3.3.1 still the issue.
Added subscribers: @Adrian1819, @PratikPB2123
In 4.0 still the problem. Could it be because of each user's video card?
A way to get around this issue is by going to File > External Data > Automatically Pack Resources.
It fixed the Cycles render not updating for me.
Automatically Packing Resources should also remove the frustration of losing texture-painted data if you forget to save it separately as an external image file.
