[2.93-A] Composite Node Output completely black, Viewer Node working from the same data. #86836
7 Participants
Reference: blender/blender#86836
Operating system: Windows 10
Graphics card: GTX 1050 TI Overclocked (Second Hand GPU)
Broken: 2.93 Alpha (Date: 2021-03-19 21:37, Branch: master)
Worked: 2.93 Alpha, Local Compilation from Source Code (Date: 2021-03-18, Commit:
51c7ff9222
) <-- Tested on Friend's ComputerDescription :
While working on a 3D model i wanted to Render a 8k shot, after a complete rendering Compositing started. Once done it gave me a "Black Silhouette" of what i rendered.
On this image you can see the Black Silhouette, the issue only happens on composite node's ouput, viewer node ouput works perfectly.
This image illustrate my current Compositing Setup
Exact steps for others to reproduce the error :
Setup a scene - in my case it's few objects, textures, compositing nodes with two output (one normal, one watermarked) - render 8k and wait for Compositing.
Due to Not-To-Share Models i'm not allowed to share my Blend File.
Added subscriber: @Aels-224
Additional Information.
Turned OptiX Denoising off and didn't got a Black Silhouette on Composite Node output.
I am currently checking to see if it has been reactivated to determine if it was a one-time problem.
It seems that everything is back to normal when re-enabling OptiX denoising and re-rendering, which seems to be a one-time problem.
Added subscriber: @lichtwerk
If this one-time problem is reproducable, then it would still be good to have a look at this.
However, we would still need a .blend file with this particular setup (models can be replaced with simple geometry), this just ensure we are all on the same page.
Greetings @lichtwerk , I haven't managed to reproduce this particular issue but I think I found a possible cause, I'm no expert so pardon me if I'm off.
While trying to reproduce it, I got this result when doing the previously mentioned steps.
Also, during the night — between my report and now — a friend tried to reproduce my issue and got almost what I just got, visually not identical tho it comes from the same compositing setup.
His theory and now mine is that multiple Composite and Viewer node — even if disable — might interact in a wrong way on to what is outputted.
Here's a clip of his side, note that he is on 2.92 (version on which the "Black Silhouette" issue also happened to me in the past).
https://cdn.discordapp.com/attachments/555448292087955456/823768556474073178/qrU850mZZo.mp4
Here's my mentionned result.
On my picture both Render Result and Viewer Node images should be identical, that said it seems that Composite and Viewer node seem to keep some kind of active status when duplicated, even if not "active" by clicking on them.
I say should since technically both Composite and Viewer node should output the non-watermark picture since the active ones are both linked to the Glare node.
Here's the Blend file, it's the one i used for the picture above
untitled.blend
In hope that it helps, don't hesitate to ask more and please pardon any delay or typos.
Added subscriber: @EAW
I have been able to reproduce the issue of the non-active render node being the one that appears in the Image Editor, but only the first time after I copied it. After that, it worked as expected. I don't feel that I have the right steps that are reproducible yet to be able to confirm.
Added subscriber: @OmarEmaraDev
The composite node ignores its active status and overrides the previous active node, while the order is not defined.
In
convert_to_operation
, it should be:@Jeroen-Bakker The code proposed from Omar seems reasonable. Do you want to have a second look or we just commit the change? :)
Yes, can be committed.
I will assign to me to land the fix.
