Video Editing (outline on the border) #86861
Open
opened 2021-03-23 21:22:52 +01:00 by Sergey · 12 comments
Operating system: Windows-10 64 Bits
Graphics card: GeForce GTX 750 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 460.89
Broken: version: 2.93.0 Alpha, branch: master, commit date: 2021-03-22 17:02, hash: 62987a6f98
Some images with an alpha channel have grey outline when scaled up and different bicubic or bilinear interpolation is used.
Issue is visible immediately after opening .blend file
#86861.zip
**System Information** Operating system: Windows-10 64 Bits Graphics card: GeForce GTX 750 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 460.89 **Blender Version** Broken: version: 2.93.0 Alpha, branch: master, commit date: 2021-03-22 17:02, hash: `62987a6f98` Worked: (newest version of Blender that worked as expected) **Short description of error** Some images with an alpha channel have grey outline when scaled up and different bicubic or bilinear interpolation is used. **Exact steps for others to reproduce the error** Issue is visible immediately after opening .blend file [#86861.zip](https://archive.blender.org/developer/F9925606/T86861.zip)
Author
Added subscriber: @SergeyA
#99485 was marked as duplicate of this issue
Member
Added subscribers: @iss, @lichtwerk
Member
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Member
@iss: is this expected behavior?
Problem here is that pixels that are out of white opaque area are transparent and black. You can check RGB channels with color sampler tool.
So when black and white pixels are interpolated during render, they are slightly grey and slightly transparent.
So technically this issue described is not a bug.
The only way to "fix" this would be to provide user control over interpolation so it can be set to none(nearest). Not sure whether this would be good solution (breaks philosophy of "should just work"). I would like to check with @Sergey what he thinks about this first.
The assumption regarding bicubic interpolation, is not correct. With transform effect strip the effect is the similar. Strip untitled.001 produces no image in your sample file. Path to image is incorrect.
During preview no interpolation(nearest) is used on transformed strips and during render bilinear interpolation is used.
Another issue is with text strip. Pixels are output as 8-bit associated alpha and VSE can't blend this format properly. It is definitely possible to improve this instance, but it has been working like this for ages so this isn't regression. But I would be fine with confirming that issue as bug and solving it when there is time to do so
@SergeyA can you please report issue with text strip separately and update this report so it focuses on one issue only?
Problem here is that pixels that are out of white opaque area are transparent and black. You can check RGB channels with color sampler tool. So when black and white pixels are interpolated during render, they are slightly grey and slightly transparent. So technically this issue described is not a bug. The only way to "fix" this would be to provide user control over interpolation so it can be set to none(nearest). Not sure whether this would be good solution (breaks philosophy of "should just work"). I would like to check with @Sergey what he thinks about this first. The assumption regarding bicubic interpolation, is not correct. With transform effect strip the effect is the similar. Strip `untitled.001` produces no image in your sample file. Path to image is incorrect. During preview no interpolation(nearest) is used on transformed strips and during render bilinear interpolation is used. Another issue is with text strip. Pixels are output as 8-bit associated alpha and VSE can't blend this format properly. It is definitely possible to improve this instance, but it has been working like this for ages so this isn't regression. But I would be fine with confirming that issue as bug and solving it when there is time to do so @SergeyA can you please report issue with text strip separately and update this report so it focuses on one issue only?
I have updated description so it describes only one issue and created better example file.
Changed status from 'Needs Developer To Reproduce' to: 'Confirmed'
Classifying this as known issue as there is no easy solution that could be done as bugfix.
@SergeyA, as workaround you can use Convert to Float option in Color panel on image strip, that will convert image to associated alpha, where this issue doesn't happen. This will reduce performance of the strip however.
Classifying this as known issue as there is no easy solution that could be done as bugfix. @SergeyA, as workaround you can use Convert to Float option in Color panel on image strip, that will convert image to associated alpha, where this issue doesn't happen. This will reduce performance of the strip however.
Author
A separate report has been generated for the problem with the outline around the white text strip https://developer.blender.org/T87337
Added subscribers: @BjornEckhardt, @OmarEmaraDev
Philipp Oeser removed the
label 2023-02-10 09:31:49 +01:00
Reference: blender/blender#86861
