Startup & Core Scripts Code Style #86943
Reference: blender/blender#86943
Motivation
Currently there are some conventions informally agreed on that have not been documented.
This aims to document the current conventions.
Proposal
https://wiki.blender.org/wiki/Style_Guide/Python should include a section for "Startup & Core Scripts"
Blender comes with scripts which are at the core of Blenders functionality:
release/scripts/startup/
, as the name suggests these run on startup and maintained by developers who work across many areas of Blender.release/scripts/modules/bpy/
the bpy module, the primary way Blender is exposed to Python.For this reason, scripts that load on startup are intended to be kept fast and simple where possible.
There are some conventions not enforced in other areas of Blender's Python code-base.
icon='WARNING'
orob.type == MESH
double quotes for text descriptions (all other strings), such aslayout.label(text="Text description")
Added subscriber: @ideasman42
Added subscriber: @dr.sybren
I think the practical effect of this is inversely proportional to the commonality of the module. For example, delaying an import of
os
oraddon_utils
will hardly have any effect, because theos
module is very likely already available insys.modules['os']
. A delayed import only avoids a single dict lookup and name assignment (import os
is then equivalent toos = sys.modules['os']
). For other, less often used modules, such aswebbrowser
orrna_xml
, I certainly agree with the late import guideline.👍
I agree, but only to the extent where it's indeed about simple UI code. "
startup
" does not equate "UI", as operators and other functionality are defined inrelease/scripts/startup/bl_operators
.For example,
release/scripts/startup/bl_operators/object_randomize_transform.py
has a functionrandomize_selected()
with rather confusing parameters. Heredelta
is a boolean,loc
,rot
, andscale
are floats, andscale_even
is a boolean again. I found in another part of the code that these loc/rot/scale floats can also beNone
. Here I feel that type annotations would certainly help readability and understandability. A similar argument could be made for the code inrelease/scripts/startup/bl_operators/bmesh/find_adjacent.py
. So here I disagree with the "no type annotations" rule, because there is a whole lot to gain in these situations.👍 Not my personal preference, but I can certainly live with this guideline.
Right, the aim is to avoid loading the module entirely as the dict lookup is negligible.
We could list some exceptions, however I'm wary of complicating rules. If anyone who writes an import needs to consult a table of modules in the wiki (that may change over time) - it risks being impractical to follow.
A simple rule such as "delay imports where possible" is easy to remember, also - for UI code we rarely need modules outside the package anyway, so having a few local imports is hardly a problem, even if a little awkward.
For operators the case to delay imports isn't so straightforward, even so. I don't think delaying imports is really such a hassle.
I'm not against type hints in general, I'd rather their inclusion be part of a more formal proposal, so we know what we're getting into and agree on the direction.
mypy --strict
for e.g.).This doesn't have to be done all at once, if we agree on a plan it can be broken up into steps.
We could move away from this. Again, I'd rather this be proposed separately from this task. It was already proposed to change during the code-quest and we agreed to keep it this way.
Startup Scripts Code Styleto Startup/Core Scripts Code StyleStartup/Core Scripts Code Styleto Startup & Core Scripts Code StyleExtended the definition of startup scripts to include the bpy module it's self.
I think it's fine to have such a list. People can still delay-import if they want, but chances are most imports aren't going to be that unique and thus without knowing they could already be adhering to that list. The list isn't that hard to make either, we can just look at
sys.modules
after a factory startup. This is what's loaded anyway, with some Blender-specific modules shortened for brevity. As far as I'm concerned, there is no use in delayed import any of these, especially when they come from Python's stdlib.The only downside, and it's a minor one, is that it potentially defers the detectability of errors (I've seen this in practice myself in other Python projects) from loading a module to executing the exact code path that imports the dependency. This means that the "load all addons" unittest is going to be slighly less effective. As I said, this is minor, and IMO doesn't outweigh faster startup.
My main concern is avoiding difficult to enforce rules, perhaps tooling could enforce this, although the exact details of modules which are loaded is probably platform spesific.
Regarding detectability of errors, it's a valid point, AFAICS it's a trade-off that that prioritizes startup time.
bl_load_py_modules
test should be able to cover these kinds of cases if it doesn't already.Added a separate proposal for type hints: #87333 (Proposal for type hint use in Blender's Python scripts)
Added subscriber: @mont29
In general proposal LGTM.
Some precisions regarding strings. C-style formatting for strings also remains the fastest afaik, there are performances concerns still about the more modern approaches?
For UI translations,
format
system is also compatible in theory (although it risks more breakage, since translators have already a hard time dealing with the basics of C-string type, and format syntax is less universal). f-strings are fully incompatible, given how they are handled by python.As for module import, not sure listing
sys.modules
after a factory startup is that much relevant, since some code will have ran as part of UI scripts and operators after the startup, so don't think this represents modules actually loaded at startup itself? Also add-ons enabled by default should not be taken into account here?But in general I would be fine if some very common modules from python's
stdlib
are excluded from this rule, too, likesys
,os
,importlib
...I am removing the
label. This is under the general rule that Design and TODO tasks should not have a status.If you believe this task is no longer relevant, feel free to close it.
