Transform node after Point Instance causes issues #87094
Reference: blender/blender#87094
Graphics card: GeForce RTX 2070 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.92
Broken: version: 2.93.0 Alpha, branch: master, commit date: 2021-03-31 07:46, hash:
645fc0c767
Worked: Yesterday's build
Instancing an object and then using a transform node AFTERWARDS will transform the instances, not the whole object as a block.
Video shows transform only effecting the instanced brick scales, instead of scaling down the whole wall. (Translation appears to work but that would look the same regardless)
2021-03-31 17-10-07.mp4
Add a cube, instance a cube on the corners. Add a transform node and try to rotate the entire instancer with instances. Only the instances will rotate about their positions.
Test file: TransformBug.blend
Added subscriber: @Erindale
Added subscriber: @filedescriptor
@Erindale Could you add the test
.blend
file to the report. That would be helpful. Thank you.Added subscriber: @HooglyBoogly
Thanks for the report! Fix incoming
This issue was referenced by
46ee9b599a
