Poisson Disk Seed Repeats distribution every 125 values #87217
6 Participants
Reference: blender/blender#87217
Graphics card: GeForce RTX 2070 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.92
Broken: version: 2.93.0 Alpha, branch: master, commit date: 2021-04-03 16:32, hash:
8681504f06
Poisson Disk distribution isn't properly randomising. Every 125 values or so the pattern will repeat with a slight offset. Changing the seed value doesn't change the distribution so much as slide the pattern over the surface.
This only seems to be an issue particularly with a subdivided mesh either via subdiv modifier or the subdivide nodes.
Open a new file, add a plane and add a geo node tree.
Add a Point Distribute node set to poisson disk and change the Seed value.
2021-04-05 18-02-00.mp4
PoissonSeedBug.blend
Added subscriber: @Erindale
Added subscriber: @victorlouis
The problem is this line in
sample_mesh_surface()
:Increasing
seed
by 1 thus effectively decreases the looptri indices that will receive a point by 1:By multiplying with the seed instead of adding it, the behavior is more random for successive seeds:
I'm not sure how this change could be made without breaking backwards compatibility though.
Another solution would be to create a single
RandomNumberGenerator rng(seed);
outside the loop over looptris, instead of creating a new rng for each looptri.Also, this might be more correct than the proposal from my previous comment:
Added subscriber: @lichtwerk
Can sort of confirm, also thx @victorlouis for taking the time and investigate!
Added subscriber: @dfelinto
Confirmed bugs need to be tagged to one of the modules to show in the queries.
I used the wrong option when setting Nodes & Physics projects. I didn't mean to remove BF Blender and the Geomtry Nodes projects.
The issue with that is that we loose all stability afaik.
Multiplying the seed with some large number seems to be the way to go here imo. Unfortunately, you are right and this changes the distribution pattern. I don't think there is a good way around that at this point, also not sure if it is worth it to make the code more complicate so that old patterns remain the same. One way to keep old distributions intact is to add a bool to the node storage that remembers whether the old or new behavior should be used.
Ah yes indeed, forgot about that. Just tried it with the rng outside the loop and it causes the points to shift around while weight painting.
This issue was referenced by
ca37d8485c
