cloth simulation often not working
Operating system:Window 10
Graphics card:quadro m2000m
Blender Version2.92
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
Short description of errorcloth simulation often not working, sometime it work, sometime not, inclue other simulation like fire or smoke,..
Philipp Oeser (lichtwerk) closed this task as Archived.Thu, Apr 8, 9:40 AM
You have a lot of double vertices (this then has zero-length edges which will mess up the simulation).
Remove them by going into editmode, select all, then do Mesh > Clean Up > Merge By Distance.
Delete Bake and bake again should work fine then.
Dont see a bug here, will close (but feel free to comment again if issues persist).
Thank you, very appreciate your work, too quick right answer,best regard
