Black Shapes #87408
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#87408
When opening blender the primitive cube is not visible, when I turn the shading on it is a flat black color. Any ideas to how I can bring it back to its default settings?
Operating system:
Graphics card:
Broken:
(example: 2.79b release)
Added subscriber: @dlip201
Added subscriber: @Alaska
We can not help you unless you provide more information like the version of Blender you're using, what version worked, what GPU and OS you're using etc.
From the description of your issue, it seems like your GPU may not be compatible with the more recent versions of Blender. You can find the requirements for Blender here: https://www.blender.org/download/requirements/
You could try updating your GPU drivers to see if it helps, here's some more information: https://docs.blender.org/manual/en/dev/troubleshooting/gpu/index.html
If you do have a old GPU that's not supported, it's likely that Blender 2.79 will work for you. It can be downloaded form here: https://www.blender.org/download/previous-versions/
Added subscriber: @ankitm
Thanks again for the report. If the problem persists please report with the required information.
