PBVH_BMESH Notes #87456
9 Participants
Reference: blender/blender#87456
Lately there's been interest in users (and some developers) in adding more topological workflows to sculptmode and/or refactoring editmode to use PBVH_BMESH. This will require much refactoring of the code, some of which has already happened as part of the DynTopo cleanup project (but not everything).
The purpose of this document is to set down some ideas for the future direction of PBVH_BMESH and how we might get there.
Current state of PBVH_BMESH
PBVH_BMESH Changes
Customdata interpolation is now supported for DynTopo.
PBVH drawing now sets GPU attributes (mostly) correctly (still need to support multiple UV layers properly).
Vertices now have a special MDynTopoVert customdata structure for storing original data.
PBVHNode->bm_unique_verts/bm_other_verts/bm_faces now use a special GSET wrapper that caches entries in a flat array for fast iteration.
Original data is no longer tied to the undo system (at all) for PBVH_BMESH.
Triangles are no longer cached in an ad-hoc way in node->bm_ortri and bm_orco.
PBVH nodes are now joined together at the end of a stroke if they lose too much topology during dyntopo. This
There is an option to draw sculpt colors in flat cells instead of the usual vcol interpolation.
General PBVH Changes
The sculpt API now has a concept of sculpt vertex references (SculptVertRef) which are indices for PBVH_FACES/GRIDS and BMVert pointers for
PBVH_BMESH. You can convert between sculpt vert refs and mesh indices with BKE_vertex_index_to_table and BKE_table_index_to_vertex.
To prevent implicit casts to/from 32-bit ints, SculptVertRef is a structure:
The same idea is used for face references too with a similar SculptFaceRef structure.
Storing Triangulations In Nodes
We should cache triangles in PBVH nodes. I've roughed out a simple api for this in temp_multires_bmesh already (there were a few truly evil bugs that necessitated it). The new data structures are below.
I've kept things as simple as possible (I was planning on doing this a lot later). Triangulations are generated lazily as with the old bm_ortri code, only instead
of flagging nodes as dirty by freeing the triangulation a new PBVH_UpdateTris flag is set in node->flag.
Some open questions are:
Should we use this for all PBVH types? If so, what should the related SCULPT_XXX api look like?
Future Steps
To make PBVH_BMESH usable outside of DynTopo (and even sculpt), the following needs to happen:
Add support for fragment shader based flat face shading to the draw system.
Added subscriber: @JosephEagar
Added subscriber: @IyadAhmed
Added subscriber: @MetinSeven-1
Added subscriber: @PabloDobarro
Added subscriber: @GeorgiaPacific
Added subscriber: @StephenSwaney
Added subscriber: @Alchimista
I am removing the
label. This is under the general rule that Design and TODO tasks should not have a status.If you believe this task is no longer relevant, feel free to close it.
