Shader not working without applying Geometry Node when converting from volumes #87462
Reference: blender/blender#87462
Operating system: MacOS Big Sur
Graphics card: None
Broken: 2.93.0
Worked: 2.92
When using the geometry node, the shader doesn't work if the mesh is converted from a volume.
If the geometry node modifier is applied, which makes the animations disappear, the shader is applied.
1 - Set shader on the default cube
2 - Use geometry node
3 - Add "points to volume" node
4 - Add "Volume to mesh" node
You will see the shader is not applied anymore.
Added subscriber: @kurisutofu
Added subscriber: @mano-wii
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
It's probably by design.
I need to study more about these volume nodes, I'm not sure how to control the material.
geo_node_volume.blend
Changed status from 'Needs Developer To Reproduce' to: 'Archived'
By default, materials are stored on the input mesh. You control that in the material properties tab:
{F10047601 size=full}
In order to set the material on a mesh created from scratch inside the node tree, switch that setting to store your materials on the object, and use the material index attribute to assign the material.
So, this is "by design", but it's also confusing, and we plan to improve the UX here in the future (just not sure how yet).
